Injection pump ?? FORD 1600
/ Injection pump ?? FORD 1600 #1
dodgefan01
LRAFB, AR
1979 Ford 1600
I will start by saying it has ran GREAT and i've never had any problems with it until now. it's got approx 1300hrs on it (i bought it used).
So i went out a few weeks ago to do some work and as i turned the key it sound like it sucked up water (gurgling sound) so i immediately stopped. i took off the filter (oil bath) and it looked quite mucky. So i cleaned it out and filled with new oil. I also changed the oil in the tractor and injection pump while i was at it. When i drained oil, it looked great BTW. Added some fresh diesel that had seafoam in it and now i'm not getting anything when i try and crank (not even smoke).
I have fuel to the injection pump (i loosen bleeder screw and fuel flows out). When i crack the lines it sort of "spits" small amounts of fuel (i'm not sure how much i should expect). I have not checked glow plugs or compression yet as i didn't think that could be it as this problem came directly after hearing what i thought was water getting into the engine.
Any help would be GREATLY appreciated. i NEED this tractor :(.
One more note, it doesn't look like all the other injection pumps iv'e seen as i've searched this forum as well as google. Mine does NOT have the access panel to see the injection pump springs. I was thinking maybe it was sticking.
/ Injection pump ?? FORD 1600 #2
You can get to the control rack by taking off the back gov. cover..
BE CAREFUL.. there is a long spring & shim under the cover..
You might be able to unscrew the cap next to the inlet bolt?? but it looks awful close to the other engine bolt??
They don't pump a lot of fuel, so your little squirt might be enough??
Are you loosening the line AT THE PUMP to see it squirt??
Loosen the line AT THE INJECTOR to bleed the air out.. wait for it to squirt THERE.. & tighten.
MAKE SURE the throttle is WIDE OPEN.. FULL THROTTLE..
I'll give this a shot.. Thanks!
So I finally got back out to work on this. I read somewhere to put gas on a rag and put over the air inlet. So I wet a rag and put over the oil bath. It turned over but didn't stay running.
Its puffing white smoke. I put in new fuel filter and bleed all the lines to the injection pump. I bled the lines at the actual injectors until it was squirting out of both of them and then tighten them down. Still nothing.
Please help
/ Injection pump ?? FORD 1600 #5
If it puffing white smoke, its getting fuel..
so check the glow plugs.. take'm out & check'm don't rely on an ohm meter, just my opinion.
Hookm up one by one to a battery charger or directly off the battery w/ alligator clips.. + on top, - on body.. should get red by 7-10 sec.
Puttm back in, THEN check to see if they're getting 12v w/the key.
Thanks. I'll get out the voltmeter tomorrow. I was thinking it still needed fuel I it was white and not black
With the exhaust pipe on, I'm not getting any smoke.
Checked plugs like you told me. They glow when hooked directly to battery and get 9v to them when wired up
/ Injection pump ?? FORD 1600 #8
You can take out an injector & hook it back up, hang it outside the engine & see if its squirting fuel when cranking..
CAUTION>> DONT get near the spray..
That's pretty much the last thing I can do. I'm leaning more and.more to the injection pump. Just doesn't seem like enough fuel is coming out of the lines. This is starting to sound really expensive.
Thanks for the pointers
/ Injection pump ?? FORD 1600 #10
It just depends on where you get it repaired & what they find..
& the pump removal isn't fun..
Did you ever take off the back cover, inorder to get to the control rack??
IF NOT, don't forget about the spring & shim in there..
No sir. I'm quite weary of that. Especially since it doesn't look like most pumps on other 1600s. I don't know what I would be looking for either.
/ Injection pump ?? FORD 1600 #12
Under the cover is a spring.. NOT a big strong spring that's gonna shoot out atcha.. Just a long "pen" type spring..
Once you have the cover off, you'll be able to get ahold of the control rack that moves the fuel on & off..
Just grab it w/ your fingers & see if it moves.. most times all it takes is to push & pull on it afew times to loosen it up..
Then put the spring on the knob on the cover, make sure the other end goes into the rack & bolt it back up..
. what are you afraid of?? It ALREADY doesn't work.. Lol
Copy that......good point. I'll keep ya posted and again, thanks. I can't afford a whole new pump. Especially aggravating since I've never had any issues with this tractor.
I took the back plate off and pushed on the "rack" a few times and found nothing broke. So I closed it up added oil, and tried her again. SHE FIRED UP!!!!!!
Thanks allot for your help. I'm guessing it got stuck for some reason? Low on oil maybe.
/ Injection pump ?? FORD 1600 #15
They don't like to sit.. ADD some fuel conditioner to the fuel..
.. & keep the pump topped off w/ FRESH oil..Oil goes stale after awhile too..
I knew your could do it w/ a little instructions.. Congrats..
2001 Generac SG0060 75kVA Natural Gas Generator (A66734)
2001 Generac...
Steiner 60in Fairway Mower Tractor Attachment (A64553)
Steiner 60in...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
2020 KENWORTH T880 TRI-AXLE HYDROVAC TRK (A67714)
2020 KENWORTH T880...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
