2018 Branson 4720CH Owner
/ 2018 Branson 4720CH Owner #1
Warsign
Kentucky
Branson 4720 CH 2018
I took possession of a 4720CH this weekend. I can not say enough good things about the CAB, the new cab design is far superior to the previous year models. The seat is fully adjustable and very comfortable with a nice wide stance. The cab has much more headroom than before, no longer is your head up in a pocket. Fit and finish is good, but not perfect. The paint has a slight over spray feeling to it. Overall appearance is impressive, and proportional.
I spent 5 hours bush hogging a very overgrown field and loved every minute of it. Bush hogging our pond dam which is on a 40 degree slope was a breeze as well. I just locked in the 4wd and backed up the slope, when I switched from backward to forward, the hydro held the machine firmly on the slope. The hydrostatic drive makes clearing around trees and fence rows a breeze. The hydro DOES produce additional noise that you just don't get in a geared tractor, but the ease of use is well worth a little noise. I averaged about 1 gallon of fuel to 1 hour of run time at 2500 RPM, which I thought was impressive.
Grill and radiator cleaning is CRITICAL, keep a leaf blower handy if you plan to bush hog heavy overgrowth. The engine never got hot, but I stopped every hour or two and cleaned off the trash.
The interstate battery is a piece of garbage, do yourself a favor and buy an AGM battery so you do not have the worry about acid leaking out the vents like I did.
When I have a chance I will share a few videos. More to come.
/ 2018 Branson 4720CH Owner #2
Another member of the Branson club. Nice! Have fun with your new toy!
That a fine looking machine right there. I also find my Branson to be very stable on steep hills. Overtime you will also realize that everything is built really heavy and strong.
/ 2018 Branson 4720CH Owner #3
I'll be tackling my steepest hills with the Bush hog soon. Second time with the Branson. Felt so stable I'm thinking of 2nd gear this time! Agree the hydro whine takes some getting used to.
/ 2018 Branson 4720CH Owner #4
Coming from a Kubota whose whine was louder I don't notice it much.
Low and slow, no need to rush it. A rock or low spot could cause roll over at a greater speed.
I don't mind the whine, just wanted others to be aware of it.
/ 2018 Branson 4720CH Owner #10
Beautiful tractor. I have always loved the color of the Branson's better then anything else out there for sale. I had a 2800 Hst for a few years but sold it after some HST pump issues it had. I am sure they have that deal figured out by now, even though they discontinued the 2800 for the more popular 2400. Because of all the dust that my acreage produces after mowing short for fire break purposes, I always fire up the compressor and blow off the whole tractor/Brush Hog because it makes for a cleaner shop and clean Tractor.
/ 2018 Branson 4720CH Owner #11
Your owner's manual should spec fuel consumption. My 6530 is spec'd at 0.046 gallons/hp/hr and that's the hp being used at the time. So at full 65 hp (2600 rated rpms) that's 2.99 gallons/hour. At 600 rpm idle it's not much.
2011 Isuzu NRR Dovetail 22ft. Flatbed Truck (A61573)
2011 Isuzu NRR...
2019 FORD F350 4X4 PICKUP TRUCK (A59912)
2019 FORD F350 4X4...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
Ripper Tooth Excavator Attachment (A61572)
Ripper Tooth...
2011 Bobcat E50M Mini Excavator (A61572)
2011 Bobcat E50M...
2017 Mack Semi (A64047)
2017 Mack Semi...
