newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,850
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
I agree, Jeff has a bunch of boilerplate. For example his treatise on "Safe hillside operation" and you didn't mention any hills.Viper Driver. jeffy always pushes the weight aspect, it is excessive/ compulsive. The mantra could easily be labeled
"BUY TOO MUCH TRACTOR"
I own both large and smaller tractors and a 2000 lb 25 gross hp tractor will perform a lot of tasks.<snip>
I also own both small and large. My 23HP B7610 fits through my 5' gates and can do most things my 50HP M4700 will do, just smaller pieces at a time. Smaller mower, moves shorter logs, lot less gravel in the bucket.
I fully understand your need to have a tractor you can "squeeze" past your choke point.
I've also a house in Mississippi where the ONLY outside access to the back is through a carport and down a brick paved path. My B7610 fits fine,
my M4700 doesn't fit in the carport.
But I can still move some big stuff with my B7610,
Not sure why you need a 35HP tractor to maintain 2 acres. Also, it won't fit within the under 60" width you need. Aside from the width of the tractor itself, you want your implements to be a bit wider than the tractor for obvious reasons. A 5' implement is of course 60" wide and will give you just 6" of clearance on each side through your 72" space. If you're comfortable with that, you're looking at a max tractor width of around 54", including the tires.
If you're new to tractors, you may be underestimating the power and capability of a 25HP tractor.
I'd suggest also be flexible a bit on maximum width, you might need to very carefully drive a 66" wide tractor through your 72" opening.
