Backhoe Outside Storage
/ Outside Storage #1
MikeR 2018
Central Pa
Kioti CK2610 HST with FEL, Rotary Cutter, Box Blade and HLA Grapple
I am planning to get a compact tractor soon, along with FEL, Grapple, Rotary Cutter, Box Blade, and (maybe) a backhoe.
I want to get an equipment shed built for everything but the equipment will be stored outside until I can prepare the site and a driveway to the site (using the tractor), as well as save up money to get the shed built.
Im concerned about storing everything outside for a few months to a year (worst case). I could cover some things with tarps, and I can get a little fabric quonset hut for the tractor for about $300.
My biggest concern is the backhoe. I have read that you should not store a BH outside because the hydraulic cylinders will get pitted. I could hold off on buying the BH but there is a $1,000 rebate when I get it with the tractor.
What is your opinion on storing this equipment outside of a building for a year or less?
/ Outside Storage #2
I have kept my tractor and implements outside for 2 yrs. now. The tractor,bushhog and woodchipper get tarps over them. Don't have a backhoe. But my box blade stays on the tractor most of the time, grader blade and pallet forks just stay uncovered. I am in the process of getting our pole barn built this week, so everything under the tarps will be inside next week !! I would think as long as you can keep the BH off the ground and tarped it will be ok. Alot of construction BHs stay outside uncovered. Enjoy your new toys !!
/ Outside Storage #3
Least cover attachment but let the air circulate,also keep attachments off the ground...plastic bag or sort cover disconnect ends.
/ Outside Storage #4
I bought my brand new tractor a couple of months ago, and was also concerned about storage. It is a 2017 model and It didn't occur to me until a few days after I bought it and I drove past the dealership at night, and saw the tractors all sitting in the parking lot, that my tractor has been sitting out in the weather for probably a whole year before I ever bought it. I went home and looked at it real close, all over, and it looks just fine. No rust, no pitting of cylinders, no fading of paint. I wouldn't want to leave it sitting in the sun for 10 years, for fear of the plastic getting all cracked, but I'm pretty sure these things are meant to be left outside in the weather (probably not for their entire life though). I wouldn't be too worried about it. As far as the backhoe is concerned, I don't know how it's arranged, but if you can store it with all the cylinders retracted, then there should be no problem. If not, a liberal application of grease to the exposed rods will help. At least put it under a tree if you can.
/ Outside Storage #5
I have a 1970 Case backhoe loader that's spent it's entire life outside in the weather and it has no pitting on the cylinders. If you're that concerned about the cylinders pitting then as Strantor said, store them fully retracted if possible. You could also spray the chrome portion weekly with WD-40.
Be careful with tarps, sometimes they are worse than leaving something uncovered. They can trap moisture underneath and it can't escape and allow the implement to dry out whereas untarped they get wet when it rains but they dry off quicker too.
/ Outside Storage #6
You shouldn't have that much trouble. Get a big canvas tarp if you're that worried.
When we store the excavator for long periods, we make sure the cylinders are all retracted as much as possible, never had a problem.
/ Outside Storage #7
Apologies if I missed it, but what part of the country are you in? Freezing rain concerns? Hail? Feet of snow? UV concerns?
/ Outside Storage
Good question. I should have told you. I am in central PA. It can be very wet and it usually has 3 days of clouds before and after each rain. We get snow and ice in the winter, but nothing like Buffalo NY.
/ Outside Storage #9
I store all attachments outside and only cover the tiller with a canvas tarp. All are stored on wooden pallets however over a gravel base. There is some fading of the paint jobs, but it doesn't affect their utility. The rusty working/digging parts shine right up when put to work. I spray the mold board plow and the potato plow with Fluid Film which helps a bit, but probably doesn't make much difference anyway. Two tractors are stored in a ShelterLogic unit...and the other is either in the garage or covered with a tarp outdoors. Been doing this for about 10 years.
Cheers,
Mike
P.S. That is a cheap blue plastic cover over a canvas tarp covering the tiller which is also sprayed with Fluid Film.
/ Outside Storage #10
My backhoe stays outside every winter. When I take it off the tractor in the autumn I cover the exposed cylinder rods with grease and then clean them off before use in the Spring. Any old grease will do - even what you removed when you cleaned your wheel bearings!
/ Outside Storage #13
My portable garage tent leaked and collapsed within 2 years, ultimately causing more damage to my tractor than if I had just left it outside. Then I built a quick and dirty pole barn.
/ Outside Storage #14
Use fluid film
Sometimes, my method varies with the season or the weather.View attachment 564797
Cheers,
Mike
Most farm equipment was designed years ago to live outside. Fluid Film is the next best thing to rubbing it down with sheep wool.
/ Outside Storage #15
Corrosion X heavy duty will stop rust in salt water. Fluid film works better than WD40 and is cheap.
/ Outside Storage #17
Outside storage - - - Ummmm I store anything that has moving parts under cover in one stall or another in my open carport. This includes - tractor, grapple, chipper & riding lawn mower. The remaining implements are out in the orchard - each on its own pallet, up and off the ground. Bottom plow, land plane grading scraper, disk harrow(oops) and roll over box blade. Been that way for the 36+ years I've lived here. I have no dedicated storage building and most likely never will.
I tried covering a couple of the implements with a tarp. Didn't make much difference - except, it provided a good spot for rodents to nest.
Speaking of nesting - - on ANY implement - - watch out for nesting wasps, hornets or yellow jackets. Especially those implements that have open ended tubes, box channels or enclosed areas. No one needs to be surprised when hooking up an implement. I speak from experience.
/ Outside Storage #18
Good point oosik. Those wasps love little places to nest......I've been trying Fluid Film spray to prevent nest where there is a likely place. For me, the "moving parts" are the FEL and tiller.....along with the sprayer and chipper/shredder and the Cyclone rake. The FEL has to be stored on a concrete surface if I ever want to get it remounted.:(
Cheers,
Mike
/ Outside Storage #19
I, too, am nearing tractor purchase toward the end of the year. I plan to get a rotary cutter, box blade and grapple. I've pretty much decided that I'll buy a 20 ft shipping container. I should be able to fit the tractor with grapple and rotary cutter inside and the bucket and box blade can live outside, stashed out of view. I may have to back the rotary cutter in and then pull forward with the grapple overhanging the cutter. I will probably eventually make an extended cover off the shipping container for the implements and other things. For me the shipping container works well with the theme of my recreational property which already has a 20 ft shipping container onsite ready for conversion to a cabin. The shipping container should add a little security, too. Though if someone has the balls to come steal a tractor, they probably have the means to crack open a shipping container.
/ Outside Storage
I am also considering what size shed I need. How wide is that shipping container? What size tractor do you anticipate getting?
2016 CASE CX37C EXCAVATOR (A65053)
2016 CASE CX37C...
2019 Chevrolet Tahoe (A64194)
2019 Chevrolet...
84 Inch Grapple Bucket (A64553)
84 Inch Grapple...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
