Grapple fabrication Started
/ Grapple fabrication Started #1
polemidis
Gold Member
Winthrop Maine
LS XG3140
Hello guys! I have been away for a while but I am back with some exciting news (for me at least! :)) Finally I started fabricating the grapple that I designed on my own.
I spent 150-200hours on developing it. And with the help of some members I finally got it.
The CAD file is Open Source for Non-Commercial reasons. Meaning take it, alter it, improve it do whatever you want, even BUILD it! The files is in Freecad format and you can edit them to your needs.
In general, Its a 63in wide grapple with 1/4" AR400 steel plate and dual lids. The Master CAD file also includes the geometry with all the angles/lengths so you can edit the parts easy to fit your needs. . I cut it on a CNC Plasma I designed and build just a few months ago. Plz ignore some bad quality cuts as I didn't had dry air for the plasma which caused a lot of trouble, and I had never used a plasma cutter before. Newbie here.
Anyway, here are some pics. More will follow as the project continues.
Also if anyone wants to build a CNC Plasma cutter, in the same repository I have the CAD files for this too, but it still needs some work with the Bill of Materials etc.
The CAD files are here.
/ Grapple fabrication Started #2
Looks good! Awesome addition to the vast amount of info here. would be nice to see it when finished too, perhaps even a video.
:thumbsup:
/ Grapple fabrication Started #3
Very interested in seeing how this turns out! I'm looking at different grapples, and I'm excited to see how yours turns out.
Keep us posted with pictures, please!
-Scott
Almost complete!! :)IMG_0518.JPG
Thank you guys for your support!!!
/ Grapple fabrication Started #5
GREAT WORK !!!!!!! More pictures please. Action shots if you can. Super job!
/ Grapple fabrication Started #6
This is super awesome! Thank you for your open source contribution! I will be following this with much interest. Can't wait to see a video of it in action. Or will I have to build it to see it operate? Haha.
/ Grapple fabrication Started #7
I bought a plasma cutter and got busy earlier in the year. The biggest issue is the offset in the pivot point for the upper teeth and the cylinder mount. I built the upper and lower teeth and then just played around with a cylinder I had and it started to fall into place. Spent a lot of time reviewing pictures and landed on a flat bottom set of teeth so it more mimics using the loader bucket. IMHO
I know what you mean :) Thats why I built a CNC plasma cutter, and designed the grapple at Freecad. So I had the EXACT angle that I wanted and the grappling force that I wanted. Even if you pay for the cutting service (I was quoted $300 for a full 4x8 sheet) it worth the trouble
So I have a few pics for you guys, and a video. More too come. And of course if you have any questions just ask!
Looking good! How much did you end spending on it?
I do not have a BOL yet.
But in general what I bought:
$0 100 hours in CAD :) (winter hours nothing else to do :)
$408 [1] 4x8 x 1/4" sheet of AR400 , I used almost all of it
$190 on 24' of 3"x1/4" square tube but I used only 6' out of 24' (for the top tube
$52 on 21' of 1"sch40 pipe, but I used only 9' (the solid pins fit perfectly inside that pipe with minimal play)
$31 on 20' of 1" Hot Rolled solid round, but I used only 3' (for solid pins)
$147 on 4x8x3/16" sheet but i used on the grapple only 1/3 of it, maybe less. Its for the plates on the lids, for cylinder protection and bracing. (In the pics I have not welded the bottom parts yet)
$100 (estimate, cannot find the bill) on 24' of 3" x 1/8" square tube (for the bottom)
$150 for 2 cylinders 2"x 6" (shipping included)
$140 for the hydraulic hoses-adapters-TEE's etc, (hoses are CHEAP for surplus center on the pre-made lengths) I was quoted about $450 on NAPA....
$1700 to build the CNC Plasma cutter and upgrade my air supply system!!! (but I could get away with $300 cutting fee and avoid that cost)
$50 in consumables (1st time plasma user, I wasted a lot due to lack of experience, and dry air!)
$30 in color/primer (with air compressor), if you buy the spray bottles it will cost 3x times that.
I do not recall how much welding wire.
EDIT: 2" x 3/8" flat bar for the mounting (SSQA style). It does not cost more than $40
A lot of frustration because of a design fault. that ruined the whole upper section. See the pictureIMG_0505.JPG. I had used to go cheap with 1/8" square tubing even though the computer analysis shown that it will break. To fix it I used 1/4" thick sq.tube, with extra 1/4" AR400 plate on top. The point of failure is where the base of the cylinder mount is welded at the top square tubing.
Dont give me the sum, I do not want to know it! :) But it sure worth it. Now I have an order for that grapple that I can build for a lot cheaper, (I already have the tubes) and I already have the CNC plasma.
And I feel cooooool!! Its my baby man! My very first one fabricated baby :)
/ Grapple fabrication Started #14
I'll give you a hint...your total is within about $200 of the new grapple you quoted in your first post for this project ;)
It's all good though, I applaud your effort and seeing it through to the end. Looks like it works well and the feeling you get knowing you built it yourself is priceless.
hahaha! But I already have an order to fabricate 1 more grapple, that will almost offset all my expenses (except the cnc plasma). And as soon as I make some pics/materials I can advertise it. I think its good side money and the customization is another plus ;)
The huge gain in money is going to be the firewood processor though. Almost all hydraulics and steel is less than $4000 comparing to $20000+ of a new machine
/ Grapple fabrication Started #16
Excellent. Recover your investment! Nice.
/ Grapple fabrication Started #17
CNC would be nice. I drew my design and transferred to 1/4" plywood templates for plasma cutting. Soaked plywood in water and they lasted for multiple cuts. I used 3/8" scrap plate. Has held up picking up large logs etc. Still not too heavy for the tractor and the teeth do take some abuse. Do you have a jaw opening measurement?
The latest revision is a little over 35" (inside measurements), It was more but I decided to shorten it. As I am using it now, I consider shortening the tines and the lids Which will give a little less opening too. The reason is that the lids are closed and I am moving logs they "play" a lot, inside the grapple (if its a few of them you cannot pinch them all), and I see that I do not often fill all that length with brush. Its personal preference as it is an all around use grapple though.
Where I am satisfied it the 1/4" thickness of the AR400. Almost everybody suggested to not go less than 3/8". Which may be a good advice for stronger tractors.
Anyway here are some videos guys (11 of them). I did not had a balast when I was shooting a few of them thats why I cannot lift the white ash log. The big pine log limits my lifting capacity. Not bad.
Grapple Videos - YouTube
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2007 Loudo 24ft T/A Dovetail Gooseneck Flatbed Trailer (A61573)
2007 Loudo 24ft...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
