2018 JD 1025r. anyone able to use 4 foot auger?
   / 2018 JD 1025r. anyone able to use 4 foot auger? #1
bfloyd4445
Oregon
1975 Ford 2000 D, 2019 JD2032R
:)I'm about to buy one of these little guys but but wish to be able to dig 4 foot post holes. All the PHD's seem to only have 3 foot or 30 inch long augers. I guess i could fabricate an extension to add with the auger in the hole? Would be better if i could find a PHD that will allow a 48 inch auger. Any ideas
   / 2018 JD 1025r. anyone able to use 4 foot auger? #2
Series one tractors are limited Cat 1 3 point machines which means the total lift is limited (mainly because of the smaller tires). I doubt you would have enough lift for a longer PHD. I can't say for sure but I doubt that my larger 2320 would be able to use a 48 inch PHD.
   / 2018 JD 1025r. anyone able to use 4 foot auger? #3
Check out Tractor Time with Tim on youtube. He has the same tractor and did an auger video. Good info.
   / 2018 JD 1025r. anyone able to use 4 foot auger? #4
Why not go for the 2025r? It has the same motor, but is a real cat 1.
Looking at some of Tim's videos, I think he many times wishes he had the 2025r instead of the 1025r he has. The base price is only about $2,300 more.
My issue with the concept is the height is limited by the length of the boom and drive shaft. So a longer boom would allow the same drive shaft angle putting the gearbox higher allowing for a longer bit. Would be easy to tweak a PHD to make it work. Another feature i would like to see would be a pto that can work in either direction.
I'll have to wait till i get mine then do some engineering to make it work and i will.
Check out Tractor Time with Tim on you tube. He has the same tractor and did an auger video. Good info.
Thanks, I'll check Tim out. I could not find one of the 1025r with PHD
I would except for the huge price difference. The 1025r filb package from the factory results in a large savings over buying the components individually then paying the dealer to install them. Example: a 1023 TLB was quoted to me at 20800, 1025r filb 19800. 2025 TLB 23500. I got the same thing from MF dealer. The gc1710 and the gc1720 FILB was substantially cheaper than the other models i asked about with dealer installed accessories.
   / 2018 JD 1025r. anyone able to use 4 foot auger? #8
Hard to directly compare a Deere to a MF.. just sayin....
I wasnt doing that i was simply saying the MF FILB packages were just like JD's much cheaper than dealer installed package.
   / 2018 JD 1025r. anyone able to use 4 foot auger? #10
It is titled Good,Bad&Ugly:Compact Tractor Post Hole Digger. It is under Tractor Time with Tim.
2024 Yongkang Liqian LQVC 2 Passenger Electric Car (A55853)
2024 Yongkang...
2019 Harley Davidson (A56859)
2019 Harley...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
Massey Fergusson 2625 (A53317)
Massey Fergusson...
TANK MANIFOLD (A58214)
(APPROX.52) UNUSED 2X4X12 LUMBER (A57192)
(APPROX.52) UNUSED...
