Thoughts on price
/ Thoughts on price #1
chris1976
Member
kubota
B2650 rops
3rd function
Industrial ties filled
Ratcheting and telescoping
Wheel spacers
58 inch tiller LP
60 inch box blade LP
60 brush hog LP
60 grapple LP
Quick attach 54 inch bucket
$25000.00
/ Thoughts on price #2
B2650 rops
3rd function
Wheel spacers
58 inch tiller LP
60 brush hog LP
60 grapple LP
$25000.00
Price seems within range with all of the implements but you will need counterweight to do much with the 60" grapple. Might want to consider a weight box. The small Kubota weight box is not expensive and there are other less expensive and more versatile aftermarket options.
SDT
/ Thoughts on price #3
You need to watch which model of BB and rotary cutter they quoted.
With Landpride, the 1xxx series is lightweight, light duty.
On the BB especially, if you want it to work you will need the 2560. They are approximately 115 lbs per ft if memory serves.
The 12 or 15 series are around 80 lbs per ft.
/ Thoughts on price #4
I would also recommend top and tilt if you will be doing any road or driveway work.
Easier to have dealer do it and wrap it in the financing then to do it yourself later.
/ Thoughts on price
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2018 Ram 1500 4x4...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2007 INTERNATIONAL 9200i 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2007 INTERNATIONAL...
iDrive TDS-2010H...
