First regen at 21 hours
/ First regen at 21 hours #1
Trikejay
Tennessee
LS XG3135
Was doing some loader work and it started to make some funny sounds, lights came on. Puff of smoke and it stank . Thought I broke something at first. Anyone else had a regen this early. It only lasted between 5 and 10 minutes.
/ First regen at 21 hours #2
On my Kubota I think it was around hour 30 and lasted about 5 minutes or so. I normally run mine at a pretty high RPM, not sure it makes a difference.
/ First regen at 21 hours #3
I have an older model (with the Shibaura engine) that does regens about every 5 hours. Normally I run my RPM's like TrikeJay does at 2200 but bump it up to 2500-2600 when in regen. I've read others posts of the newer models with the LS engine doing early regens and don't see this as a problem. I've also read these newer engines like to be run at higher RPM's. Running lower RPM's seems to make them soot up faster. I always check the fuel gauge when I put it away to see if it needs refilling and if its in regen cycle I see the lights. Other than when checking fuel or temp gauges I hardly ever notice when a regen cycle has started.
/ First regen at 21 hours #4
You do a lot of idling down?
My first one was in the low 50 hour range and pretty uneventful. After experiencing it, I consider it a non-event since I was able to continue work during the process. The only reason I even noticed was because of the dash lights and smell.
/ First regen at 21 hours #5
So where's the clean air benefit? Sure the Tier IV engines produce less contaminants, but we have to run them at much higher RPMs and burn more fuel.
They produce less pollution per gallon of fuel burned, but we burn more gallons to achieve that goal. Then there's the added pollution from extraction the crude oil from the ground, the refineries to produce the diesel fuel and the transportation to provide that extra fuel burned to the distributors and finally to the end consumer. :confused3:
/ First regen at 21 hours #6
You're not confused, you are just using common sense which is something politicians and bean counters know nothing about.
Reminds me of an obit someone sent me below.
/ First regen at 21 hours #7
Except that my 40 hp LS only uses a bit less than a gallon per hour when revved up so that seems pretty efficient to me compared to other equipment I've used.
I do idle down a lot when I'm jumping off the tractor for a minute or two to load sticks on to pallet Forks. I just can't leave it all high revving while I'm off the tractor. Just seems wrong. I'm idling about 30% of the time and the rest of the time it's between 1800 and 2600 RPMs. I'm pretty satisfied with the fuel economy. Doesn't seem to burning excessive amount of fuel.
/ First regen at 21 hours #9
it seems to make more sense to just disable this, it's not like you need to have it inspected like a road vehicle.. why not just remove the filter?..
/ First regen at 21 hours #10
This is pretty ironic. I was coming here to post the exact same thing; I don't know whether it's better forum etiquette to create a duplicate thread or highjack this one.
I have a brand new LS XR4140H (20.8hrs on it) and yesterday I was also doing some loader work, and noticed a funny smell. I got down and checked if anything plastic was melting on the exhaust, nothing, kept working. A few minutes later this regen light comes on. I see that you have two lights on; I only had one. It did not last very long. Maybe 30 sec the light was on and then went away.
Is this normal?
/ First regen at 21 hours #11
The two lights are actually independent. The one light tells you its regenerating, the other is the light that tells you the exhaust is hot and it comes on after the first.
I don’t think idling is necessarily bad. If the engine is thoroughly warmed up, bringing it down to slow idle for a few minutes doesn’t seem to soot up the dpf.
/ First regen at 21 hours #12
Mine so far have been at 40, 57, and 72 hours. Mine idles probably 50 percent of the time. It smells when regening of coarse, but I’m able to operate through the regen without a problem, while regening though I do try to keep the RPMs above 2000 RPMs.
/ First regen at 21 hours #13
No, not understanding how something works is not the same thing as common sense. One of the issues you're running into is that you are vastly oversimplifying or omitting how the emissions system works, what the unit measurement is of the emissions reduction (measured over fixed time, not gallons of fuel), how it's tested, and the impact to fuel consumption.
The really cool thing about Tier 4 is that with minimal increase in cost, these manufacturer's are finding new, better ways to reduce these harmful gasses and some of these methods actually increase fuel economy. People are wired to dislike change so I understand the grumbling, but when you start comparing benefits and drawbacks to emissions regulations, it is overwhelmingly beneficial to our pocketbooks over the life of the machine, our health, and the environment.
/ First regen at 21 hours #14
I don稚 think idling is necessarily bad. If the engine is thoroughly warmed up, bringing it down to slow idle for a few minutes doesn稚 seem to soot up the dpf.
Your explanation makes sense but I am curious where you learned the meaning of the "regen with thermometer" indicator. The Manual just shows "regenerating" and "regen inhibited" indicators. This "regen with thermometer" indicator is a 3rd indicator not shown or described in the manual.
So now I'm curious if I even went into regen or not. I smelled the smell but I never saw the the actual regen indicator turn on. I've had the engine up to this temp plenty of times before and never saw the "regen with thermometer" indicator. Also never smelled the smell (this is my first tractor, first turbo engine, and first diesel engine; I'm not sure that what I smelled was the smell of regen).
/ First regen at 21 hours #15
I have also noticed that ULSD has a different smell itself. Not as nasty smelling or as strong smelling as the old diesel.
/ First regen at 21 hours #16
I have 23hrs on my 6168cps and have not had a regen yet. Dealer said it would be around the 30hr mark.
/ First regen at 21 hours #17
Maybe the reason for early regen is caused by how many times you start the tractor up.
I have noticed with my little xj the only time it has any visible particulates coming out of the exhaust is on startup but once its up to temp, nothing... even under heavy load when using the loader or box blade and almost stalling the engine.
/ First regen at 21 hours #18
I just happened to look at the hour meter on my new XR4155HC when it turned to exactly 50.0 hours. At same time the first “regen” light came on. This light indicates that the diesel particulate filter (DPF) is being brought up to temperature. The second indicator comes on when the DPF is at full “regen” temperature and stays on during the full cycle which was a bit over 20 minutes, as I recall. This was my first “regen” cycle.
My previous XR4046HC would “regen” on about 5 hour intervals.
I run at 1500 rpm plus at all times, and 2400 rpm when mowing.
The only time I “idle” is for a couple of minutes at startup, a bit longer when it’s cold.
A “regen” cycle shouldn’t effect your operation unless you’re doing something in tall dry grass. In that case get out of that area until the cycle is over.
/ First regen at 21 hours #19
Yeah... my XR3135H did its first Regen around the same time. I also thought something broke when the revs went up and it began to smell "Hot". There was so much glare on the dash that I could not see the Regen Icons without shading them with my hand. It has regen'd twice in 54 hours.
/ First regen at 21 hours #20
I believe you are too narrowly focused. One of the big issues you are ignoring is all the extra pollution produced while pumping crude, refining it, and transporting it, just to meet the exhaust emission standards of Tier 4 which must be run at higher RPMs consumer more fuel than was necessary than without the mandated Tier 4 standards. The end result doesn't always justify the means.............
One example of wasted fuel: Many of us here on TBN know it doesn't take near 2200+/- engine RPMs to run our backhoes and would prefer not to if it wasn't for the Tier 4 exhaust requirements.
2006 International 7600 T/A Flatbed Truck (A64194)
2006 International...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
John Deere 980 28' Field Cultivator (A66285)
John Deere 980 28'...
1994 Freightliner Day Cab (A62613)
1994 Freightliner...
Landhero 10' x 10' Metal Shed (A66408)
Landhero 10' x 10'...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
