Comfortable RPM for CUT/SCUT
   / Comfortable RPM for CUT/SCUT #1
John Fitzgerald
Elkins, Arkansas
XJ2025H same as NH Boomer 24
What RPM do you run your diesel tractor when you are doing general chores, like hauling dirt in the bucket, and spreading gravel? I like to run 1600-1700, still plenty of power, and fairly quiet, compared to the 2430 RPM when the rotary cutter is in use. It seems to sip diesel very slowly at 1600-1700.
   / Comfortable RPM for CUT/SCUT #2
It depends on the power output I need. Usually around 1500/2000 rpm
   / Comfortable RPM for CUT/SCUT #3
My Branson is supposed to be run between 2000 and 2500 to keep the DPF happy. They put a green band from 2000-2500 on the tach. Most of the non-PTO time when I don't need power I'm at 2000. Sometimes I'll use less when I am working around another person and want keep the noise down. When I'm driving around I leave the throttle at idle and let the linked HST up the rpms.
   / Comfortable RPM for CUT/SCUT #4
It is strictly dependent upon the power needs. Running around - moving big rock or chunk of pine tree in the grapple - - around 1650 - maybe up to 1850. Running the pto chipper - takes 2250 to get 540. Ditching with my heavy duty rear blade - sometimes up to 2200 to 2400. I have never found a reason to "red line" the engine at 2600.
My M6040 is 2009 - - so it is Tier 3.
   / Comfortable RPM for CUT/SCUT #5
Depends on the power needs. If the PTO is running, then 2150 to 2200. Other chores 1700 or more. Driving around about 1600 to 1700. Mine has a DPF, so I know they say to run 2000 to 2200, but I don't always run that high.
   / Comfortable RPM for CUT/SCUT #6
I'm referring to my M7060 in the post above.
   / Comfortable RPM for CUT/SCUT #7
I have about 500 hours on my 2013 B2920. Most of those hours have been operating a flail mower at wide-open throttle. Slightly past peak 540 PTO red mark...as far as the throttle will go. Same thing for cutting grass with the 60" belly mower. For loader work, usually 2200RPM or so...the loader works much quicker with RPM.
   / Comfortable RPM for CUT/SCUT #8
My TC 33 has a sweet spot at 1500 to 1700 rpm. I usually run it like that for loader work and general putting around. About 1900 to 2000 when running the tiller.
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
John Deere XUV 550S4 (A56469)
John Deere XUV...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
