Tiller Working Depth on PTO driven rotary tillers - Larry
   / Working Depth on PTO driven rotary tillers - Larry #1
larrymyers
North Central OK.
55 hp T2410 New Holland
I need to purchase a 6 ft. PTO driven rotary tiller.
Because both are available near-by, am deciding between King Kutter and County Line brands. Both are close in appearance and price difference is not big.
However, the King Kutter brand has reverse routine tines and an advertised working depth of 8 inches while the County Line brand comes as forward rotation but can be reversed but working depth is advertised as only 4 inches, which the company verifies in their Q/A section.
Questions
Can someone explain the difference between the working depths?
Would the working depth of the County Line increase if rotation was reversed.
Thanks a million in advance.
   / Working Depth on PTO driven rotary tillers - Larry #2
Larry, I can't help you with your question, but can help your post get more "looks." Your post is tagged "Larry" so no one will know what the topic is unless they open your post. Many people will not open something just stating Larry. You need to tag your post - not with your name - but with something about your question, e.g., "Need help selecting a PTO Rotary Tiller".
   / Working Depth on PTO driven rotary tillers - Larry #3
I like king kutter.
Welcome to TBN Larry!!!!
   / Working Depth on PTO driven rotary tillers - Larry #4
Welcome to TBN and the forum - Larry. Beowulf makes a good point. Start a new post in the "Attachment" area.
I would not vouch for the 8" depth for either tiller - unless you are talking about very soft, fluffy ground.
I do know that counter-rotating tine tillers will generally do better when breaking virgin ground.
I had a Troy Bilt 8 hp Horse with counter-rotating tines. It should have been called "Troy Bilt Wild Bucking Bronco". It was a handful to control when opening up virgin ground. But it did a very good job of it.
   / Working Depth on PTO driven rotary tillers - Larry #5
Not sure what hp your tractor is but a 6'er will need some hp.
I have a Carronni 4' tiller that my 35 hp tractor handles very well.
My tiller has adjustable "shoes" on each side that I can set depth with but I have them all the way up.
It is forward turning and does a fantastic job, WAY better that the walk behind it replaced!
Pic is how good it tills soil.
   / Working Depth on PTO driven rotary tillers - Larry #6
IMHO, I doubt that the "working depth" of forward or reverse rotating tiller would differ much for most of us. If you are putting it on the 24 HP tractor, I'd think that a 6 foot tiller would be too much for it. From reading many of such posts, I'd guess that the general line of King Kutter and TSC's County Line are equal in quality. Kutter makes a "Professional" level however.
I use a LandPride 54 inch forward rotating tiller doing small gardens for myself and others .....with much satisfaction.....usually after plowing, but breaking turf on some occasions.
Welcome to TBN Larry...What's your general location where you sign in?
   / Working Depth on PTO driven rotary tillers - Larry #7
Welcome to TBN, Larry. :thumbsup:
Some TBN members asked that we change the title of your thread so you'll get some responses, so we did.
Good luck with your search.
   / Working Depth on PTO driven rotary tillers - Larry #8
Rural king has king cutter and country way tillers .The country way tillers are considerably cheaper in price, They look well made.But i think a 6 ft one may be to big for your rig.
   / Working Depth on PTO driven rotary tillers - Larry #9
Questions
If you are wanting to use a 6' reverse tiller with any real depth, you are going to need a lot of traction to pull it through hard ground. Probably more than your tractor will do without adding a lot of weight. Also, if you hit larger rocks or tree roots with a reverse tiller, your tractor will come to an abrupt stop.
Thanks Beowulf,
That was my first post. The blank called for Title and I typed Larry instead of Mr. After your advise I just did a new post with the proper Title.
After which I discovered the Edit choice. Anyway, thanks a million from an approaching 78 year old Okie.
Thanks - it was needed
   / Working Depth on PTO driven rotary tillers - Larry #12
   / Working Depth on PTO driven rotary tillers - Larry #13
I don't like the counter rotating tines. I think they are kind of a fad. The standard rotation tines till in green manures better. And in my opinion they kill weeds better by chopping down on them instead of lifting them up and over the tines. Tilling depth will be about half the tine diameter. If the rotor and tines are 16 inches it will get down to about 8 if you go over it about three times. Your a bit light on the horsepower but if you go slow and repeat you should be able to get down there. Other than Kuhn tillers all the tillers I've used have to be cleaned off the wrapping of the weeds unless you mow them first. Quite a chore. Tillers till wider than they are rated seems to me and I would recommend you get a 5 footer standard rotation tine one. Even that will make your tractor grunt
   / Working Depth on PTO driven rotary tillers - Larry #14
My tillers are forward rotating only, and mine will till to 8" deep, so you don't have to have reverse rotation to go 8" deep. You just need a tiller designed to go that deep in the first place.
I've never needed a reverse rotating tiller so I never bought one.
SR
   / Working Depth on PTO driven rotary tillers - Larry #15
I have a Kubota L235 (23.5 engine HP and 19 PTO HP) running a KK 5' tiller. It is supposed to be to big for the tractor, but as long as I take it easy, it works just fine. 1st gear so I don't go to fast and 4 wheel drive for the traction, otherwise the tiller will push the tractor. I also use multiple passes starting with a shallow depth and can get a really nice seed bed. It will also chew up some pretty hard and rocky ground.
The tiller has skid shoes to set the depth, but as the soil is broken up the skid shoes sink into the soil an inch or two. I do not know how deep it goes, but it's more than enough for anything I've ever needed to do.
   / Working Depth on PTO driven rotary tillers - Larry #16
Larry's tractor is a 55hp unit, a 5` tiller will not be much of a load for it. The 73" width will make tilling without tire ruts pretty difficult, a wider tiller would make more sense.
   / Working Depth on PTO driven rotary tillers - Larry #17
I use a 5’ king cutter behind a l3600 Kubota in good old missouri clay. To get nice soil takes a reverse then forward pass twice. Virgin soil will really make those 36 horses grunt. I really wish for a crawler gear as 1st gear is just too fast at rated pto engine speeds. I’m pretty sure if I had crawler gear I could half my passes
   / Working Depth on PTO driven rotary tillers - Larry #18
A 60" KK tiller behind my TC33D was no problem. I took the shoes off and I bury it in good soil.
   / Working Depth on PTO driven rotary tillers - Larry #19
I have a 6' KK tiller that has made it through its 4th season and is holding up very well.
When I bought it, I was concerned about the "advertised" 8" working depth since the tines only extend 3 or 4 inches past the skids when set to the deepest position. I called KK and asked to talk to a technician, was told the working depth is based on multiple passes that allow the skids to sink into the ground.
The KK is advertised as being Quick Hitch Ready, but the hooks on my Speeco QH wouldn't fit between the pins and frame of the tiller. My blue tip wrench made quick work of adding clearance and all is well now.
   / Working Depth on PTO driven rotary tillers - Larry #20
Mine is Bush Hog brand so can't comment on the 2 brands you want. But it is forward rotating and I would not want reverse. Forward it will at least climb or hop on a buried rock - I can't imagine what a good rock would do if tines were going other way - I would assume lots of broken tines or time replacing shear pins. VERY impressed with how it turned my clay into powder.... I'm using a 6' with 45/34HP but seems like there is plenty of power to spare - doesn't seem like needs nearly that much.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2016 FREIGHTLINER...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56438)
Adams Load Out...
2020 MACK P164T (A58214)
2020 MACK P164T...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
