problem removing NH flail mower bearings (roller)
/ problem removing NH flail mower bearings (roller) #1
sreavis
triad area, north carolina
kubota, MF, Ford
I bought a New Holland 917H, the bearings on the roller (rides on the ground) need replacing (1 had failed completely). They are in the height adjustment housing. One is intact within the housing) the other had failed and just has the inner and outer race left. No luck removing the housing with 3 jaw puller and heat. Any insight would be greatly appreciated. I'm hooked on flail mowers since I bought my 6' Caroni flail and got a great deal on this 90" NH.
Scott in NC
/ problem removing NH flail mower bearings (roller) #2
Cut the race with a dremel and use a blunt chisel to split it. Eye protection, gloves and long sleeves recommended.
/ problem removing NH flail mower bearings (roller) #3
You have two E rings that are holding the roller in place if you have the sealed end cap type of bearing and roller holder.
/ problem removing NH flail mower bearings (roller) #4
Scott in NC
We always remove the stuck bearing housing in this way. Designer should think about if easy to maintain it.
I will take a few pictures and post so you can the issue. Many thanks for taking the time to assist. Scott
/ problem removing NH flail mower bearings (roller) #6
Heating the housing often works. Both the housing and the race will expand but the housing expands more. You can try cooling the race but that can be difficult.
I've used the dremel and chisel trick too. Cutoff wheel is the best if you can get it in there. The race will be hard so regular HSS bits won't do it.
/ problem removing NH flail mower bearings (roller) #7
Scott, for the race (item 15) stuck in the bearing housing (item 18) see pic, if you have a welder weld three 1 inch beads on the inside of the race and let it cool. The welds will shrink the race and it should come out of the housing (item 18) with no real effort.
/ problem removing NH flail mower bearings (roller) #8
I would like to know if part number 23 which is the E ring was removed???
Here are a few pics. The bearing holder is also the height adjustment for the roller. There is a snap ring that holds the bearing assembly. Little room behind the assembly, I ground down the feet of my 3 legged puller to fit behind the assembly and heated the stuck inner bearing with a torch but it would not budge. Difficult to get good assess with the torch. Hard to get a split bearing puller behind it because of the height adjustment plate. No room for a die grinder, cutting the inner bearing is not an option without risking damaging the snap ring groove. I wonder how the dealer mechanics removed this assembly to replace the bearings?IMG_0742.jpgIMG_0743.jpgIMG_0742.jpg
Assembly is the bearing holder/height adjustment, then the bearing then the snap ring unless I being a big dummy, which is possible.
/ problem removing NH flail mower bearings (roller) #11
If you remove the remaining rollers/balls can you get the housing off the shaft (with the outer race in it)? If there's a seal or shield you'd have to pull it apart.
Then you'd have the inner race stuck on the shaft and the outer in the housing. That is where I thought you were from the description.
There is only a few rollers left. You can put them all to one side and pull the bearing off center to get more space between inner and outer race. You may need to grind the edge of the race with a dremel to get enough clearance to remove rollers.
It appears to me that it has to come off as an assembly (which I attempted to do with a hub puller and heat. The back of the bearing holder/height adjustment supports the back of the bearing and will not clear the inner bearing.. Not enough clearance for a dremel. It is part #11 and #1 on the parts sheet. Maybe I didn't get the inner hot enough but it is hard as the rest of the assembly acts as a heat sinkInkedParts_L2jpg.jpg
/ problem removing NH flail mower bearings (roller) #13
OK, did you remove the E ring(part #14) on both ends???
It is part # 11 on the other parts lists.
/ problem removing NH flail mower bearings (roller) #14
Can you attack the inner race from the outer side with a tiny dremel cutoff wheel or stone or carbide cutter? The race is big enough that it will take a while. When I have done this I have not had to cut all the way through. One you have removed enough material the race breaks from tension or it can be broken with a hammer and punch or chisel.
If there is a circlip on the end of the shaft that means that it's not supposed to be a super tight press fit. Could the end of the shaft have been damaged in a way that essentially peens it over? Can you drive the inner race deeper on the shaft without too much effort? Then you could get clearance to grind the shaft down a little. If you damage a small part of the circlip slot or a small part of the shaft where the bearing seats it should still be functional.
There is no damage (fortunately) to the end of the shaft or the ring groove. The E clips came off easily. I removed the remaining ball bearings and seal debris to make more room and will get better position with the torch (or dremel) and try and get some circular movement with a chisel as you suggested. then maybe my gear puller will pull the assembly off. Confused as to why Ford/NH would design it this way. My Caroni, the bearing housing comes off first to give you access to the bearing. Many thanks to everyones input.
/ problem removing NH flail mower bearings (roller) #16
If you have a welder that trick works very well.
After welding on the races will shrink and fall out.
/ problem removing NH flail mower bearings (roller) #17
Hello sreavis,
Those bearings were shrink fit on the tapered rear rollers shaft stubs if I remember my history of them as they would have spun on the rear roller stub if they were a slip fit.
I am going to suggest that you purchase a supply of dry ice and have some good duck tape on hand to shrink the roller and or stub shaft after wrapping it with a towel filled with broken up dry ice and then taping the towel around the shaft or the circumference of the roller to chill the entire side of that rear roller with dry ice.
Plan on replacing the opposing bearing as well to save a lot of extra work and filling the swear jar.
Hello sreavis,
tape the dry ice on the roller itself on the end closest to the bearing housing, correct? That makes most sense especially replacing the other side which is intact. Still wonder how the dealer mechanic. I have a factory service manual and it makes no mention of a factory puller or any special technique for that matter. Thanks again, the one positive note on fixing old equipment is getting on the forum and learning new approaches and techniques.
/ problem removing NH flail mower bearings (roller) #19
The more dry ice being broken and wrapped in a thin towel around and near the bearing the better. Please do not burn your hands.
If you can fit three blocks around the roller and duck tape it with an old thin towel all the better as you break the fourth block up and get the chunks as close to the stub shaft as possible and use another old towel to wrap the dry ice around there as well.
If you can save the inner race all the better to determine if you have a press fit bearing or shrink fit bearing.
If you have a good set of micrometers you will be able to tell if the roller stub is tapered after you give it a thorough cleaning with alcohol and a small steel scrub brush(only if needed) and 400 grit emery paper.
If its a shrink fit bearing you will need to rent a bearing heater or plan on using the oven as long as you have thick oven mits.
/ problem removing NH flail mower bearings (roller) #20
I had to replace a very similar bearing on the tailgate of our Ford 552 round baler last year. I used the cutting torch to get the inner bearing race cherry red, then I was able to smack the housing with a hammer and pop the whole bearing assembly off of the shaft.
In my case, between me inside of the bearing and the roller, there was a free-floating piece of round pipe that is used to prevent trash from getting wrapped around the shaft and getting into the bearing
Aaron Z
POWELL / COLE 6R RIPPER (A63291)
POWELL / COLE 6R...
HARDEE DITCH BANK MOWER PARTS (A63291)
HARDEE DITCH BANK...
KSI Conveyor (A63688)
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
