What type of steel for a new drawbar?
   / What type of steel for a new drawbar? #12
Find a mag drill with annular cutters. Much easier, faster, and cheaper.
If mild steel will work, use 1018. If limited on space, 1045 or 1144 or 4140 will provide a bit more strength but at a greatly increased cost. (About 4 times) A machine shop that works with oil field or heavy industry may have good access to material.
   / What type of steel for a new drawbar? #14
I was going to suggest something like Tractor Seabee. Usually you can buy a draw bar for $30. or whatever at a tractor supply outlet. I've had a few tractors over the years but not in a farming situation and only needed one hole in any of the draw bars.
Al
   / What type of steel for a new drawbar? #15
From the OP's description I think he is looking for a flat (not offset) SWINGING drawbar the type that is attaches under the tractor rear axle housing.
As such he was not looking for a three point hitch drawbar like the one Tractor Seabee listed.
Edit. Oops I just noticed Ron asked if he could ADAPT it. I’m the perfect example of “Stay in school, kids”
   / What type of steel for a new drawbar? #16
This is a good example of trying to second guess what the OP really has where PICTURES would zero us right in on a solution. If OP is making something; I believe quality draw bar material is forged steel.
Ron
   / What type of steel for a new drawbar? #17
Ron
You certainly are right. We are just wasting time guessing. Pictures would be best. But then, I just now read the "your land is my land" thread. I don't expect much zeroing in on a solution from my fellow members.
Off topic and a pet peeve but "forged steel" is like saying "cooked meat" or "liquid fuel". It describes a fabrication method not a chosen material.
   / What type of steel for a new drawbar? #18
We want 'perforated' steel, if not 'aircraft quality' ... or at least 'billet' ... :laughing::laughing::laughing:
I'm sure bent or dog-leg drawbars are cold-formed from cold-rolled steel, as witness marks illustrate on those I've seen. Carbon steels have little to no improvement of the 'give' we expect them to survive. Without such, bigger stuff breaks when pushed.
IMO, anything besides 1018 or A 36 is overkill and over-priced. If an entire Reese-type hitch can be made of 'mild steel' (also FEL, truck chassis, etc) it's probably good enough for a drawbar that might be thought of a 'safety breakaway' in lieu of a cracked housing. Trust makers to use the lowest cost stuff that works.
Gee, how many of us have ever snapped one off? :confused:
btw, if using a bridge reamer I'd still use the vertical mill or a drill press, tho' not everybody has 'em.
   / What type of steel for a new drawbar? #19
   / What type of steel for a new drawbar? #20
As big and heavy as my OEM draw bar is - 1.75 x 2.75 x 24 - it shouldn't need to be a really special grade of steel. But I read somewhere - it is a special high carbon steel. At $175 OEM replacement cost - it must have a little gold in it also.
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
Bucket (A55973)
Bucket (A55973)
