Gasless MIG question
/ Gasless MIG question #11
When I finish is there any reason why I cannot leave the wire in the feeder and extending from the tip, seems a pain to remove it each time it is used or is there a deterioration issue?
Can you use it again before it gets rusty? How dusty is your place? ( one of my former customers had canvas straps wide enough to fit between each side of the spool. One end had an eye that fit over a bolt on his feeder. The other end was weighted. It kept the grinder dust off his wire.) I leave mine on the machine.
There is another kind of flux cored that welds better. It is a little expensive. It uses a little co2 and makes its own shield too. You run it the same polarity as your solid wire.
/ Gasless MIG question #12
I always have left the stuff I use the most. .035 flux core in the gun. Never a problem. I take quart sliced zip locks and store the 2lb reels I知 not using though. Bigger baggies for the 11 lb reels. Because I live in the Arctic Swamp when winter hits i don稚 weld much so the Hobart goes in the warm cellar next to the furnace.
Nnnthe best way I know to wreck a welder is leave it plugged in during lightning season. Personal experience there
/ Gasless MIG question #13
Welcome to TBN Lelandwelds!
Lis2323 Welding Web & GJ
/ Gasless MIG question #14
At the the big box stores you can get a roll of thin plastic on a cardboard core. It's used for shrink wrapping anything. 4" wide and about a mile of plastic wrap on it. ( Or Glad Wrap works too ) I used to throw a desiccant pouch in the spool and wrap it up with the plastic wrap and tape it shut. Keeps rust out and preserves the quality of the cored wires which I seldom ever used. Also used to use a foodsaver vacuum sealer.
/ Gasless MIG question #15
Here’s a pic of the pallet wrap yomax mentioned.
This plastic cover for my bench feeder helps keep the wire relatively dust free.
I use a heavy ply plastic bag for part rolls in storage.
+ Ground on gasless/flux core not sure without looking at the manual what solid wire is but suspect - Ground.
I cover everything with a sheet when I am finished mainly because the birds like to spread superphosphate over everything, no matter how well I seal up the building they seem to get in, the sheet also keeps off dust and any dampness in the air, I use an old flannelette sheet as it doesn't seem to get damp and nothing gets past it, I tried a nylon fly sheet off an old tent and moisture underneath was a problem.
/ Gasless MIG question #17
Flux core (FCAW), DCEN (Electrode Negative).. Ground Positive..
Solid wire (GMAW), DCEP (Electrode Positive)... Ground Negative..
I use a bit of scotch brite abrasive pad folded over and held in place with paper clamp to scrub wire as it enters tensioner/drive roller...
Lots of good stuff at link beblow...
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Dale
/ Gasless MIG question #18
I think the process in question that Lelandwelds posted was FCAW-S also known as Outershield or Dual Shield which is usually electrode positive but apparently sometimes electrode negative depending on the wire.
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
Chemical Containers Tank (A57148)
Chemical...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2008 CAT 305C (A53317)
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
