Gasless MIG question
/ Gasless MIG question #11
When I finish is there any reason why I cannot leave the wire in the feeder and extending from the tip, seems a pain to remove it each time it is used or is there a deterioration issue?
Can you use it again before it gets rusty? How dusty is your place? ( one of my former customers had canvas straps wide enough to fit between each side of the spool. One end had an eye that fit over a bolt on his feeder. The other end was weighted. It kept the grinder dust off his wire.) I leave mine on the machine.
There is another kind of flux cored that welds better. It is a little expensive. It uses a little co2 and makes its own shield too. You run it the same polarity as your solid wire.
/ Gasless MIG question #12
I always have left the stuff I use the most. .035 flux core in the gun. Never a problem. I take quart sliced zip locks and store the 2lb reels I知 not using though. Bigger baggies for the 11 lb reels. Because I live in the Arctic Swamp when winter hits i don稚 weld much so the Hobart goes in the warm cellar next to the furnace.
Nnnthe best way I know to wreck a welder is leave it plugged in during lightning season. Personal experience there
/ Gasless MIG question #13
Welcome to TBN Lelandwelds!
Lis2323 Welding Web & GJ
/ Gasless MIG question #14
At the the big box stores you can get a roll of thin plastic on a cardboard core. It's used for shrink wrapping anything. 4" wide and about a mile of plastic wrap on it. ( Or Glad Wrap works too ) I used to throw a desiccant pouch in the spool and wrap it up with the plastic wrap and tape it shut. Keeps rust out and preserves the quality of the cored wires which I seldom ever used. Also used to use a foodsaver vacuum sealer.
/ Gasless MIG question #15
Here’s a pic of the pallet wrap yomax mentioned.
This plastic cover for my bench feeder helps keep the wire relatively dust free.
I use a heavy ply plastic bag for part rolls in storage.
+ Ground on gasless/flux core not sure without looking at the manual what solid wire is but suspect - Ground.
I cover everything with a sheet when I am finished mainly because the birds like to spread superphosphate over everything, no matter how well I seal up the building they seem to get in, the sheet also keeps off dust and any dampness in the air, I use an old flannelette sheet as it doesn't seem to get damp and nothing gets past it, I tried a nylon fly sheet off an old tent and moisture underneath was a problem.
/ Gasless MIG question #17
Flux core (FCAW), DCEN (Electrode Negative).. Ground Positive..
Solid wire (GMAW), DCEP (Electrode Positive)... Ground Negative..
I use a bit of scotch brite abrasive pad folded over and held in place with paper clamp to scrub wire as it enters tensioner/drive roller...
Lots of good stuff at link beblow...
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Dale
/ Gasless MIG question #18
I think the process in question that Lelandwelds posted was FCAW-S also known as Outershield or Dual Shield which is usually electrode positive but apparently sometimes electrode negative depending on the wire.
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
1990 Ingersoll Rand 175 S/A Towable Air Compressor (A59228)
1990 Ingersoll...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2018 John Deere HPX615E 4x4 Diesel Utility Cart (A59228)
2018 John Deere...
2016 ExMark Vantage 48in Stand-On Commercial Zero Turn Mower (A59228)
2016 ExMark...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
