Buying Advice First time tractor owner - soon
/ First time tractor owner - soon #1
MikeR 2018
Central Pa
Kioti CK2610 HST with FEL, Rotary Cutter, Box Blade and HLA Grapple
I am new to tractors and this forum, but I have been reading a lot. We live on 12 acres. 8 acres wooded mountain land, 2 acres flat with scrub brush and trees, plus another 2 acres for house, yard, barn and horse pasture.
I want to maintain and expand the mountain trails, clear the scrub brush, put some French drains in the wet areas, and maintain gravel drives. I want a small tractor due to some tight spots, but subcompacts lack the ground clearance.
I have a good Kioti dealer close by. Here is his offer: CK2510 with FEL, Backhoe with 12'' bucket, 48'' Root Grapple , 48'' bush hog, quick attach, remote hydraulics, 3rd function and beet juice I the tires. His final price is $27,575 plus tax.
Do you see a glaring beginner errors in my list?
Would you add or remove anything?
Does this price seem about right for this package in 2018?
/ First time tractor owner - soon #3
If HST the 2510 only has a two-range transmission. Often known as "too low or too high". ;)
Which tires?
Seems just a tad high, but I haven't shopped for years.
Which tires?
Industrial tires.
I saw the low/high but didn't think that was worth an upgrade. (just a guess)
I've bought a lot of smaller machines from this place. The are not the cheapest but have the best support.
/ First time tractor owner - soon #6
Which tires?
My property and task list are very similar to the OP's. I was worried about the 2-range tranny too. But box-blading, grading, digging, clearing brush, making trails and other woods-work, are all slow-speed tasks. On my terrain, tasks are safer done slowly anyhow. Low for work; high for travel. I can see how a middle range might come in handy for mowing, but I have another machine for that.
Maybe the BH explains the higher price? I got talked out of buying a backhoe here on TBN and I'm glad. I'm able to do a lot of the work I thought I needed a BH for, with my tilt blade.
Additions: A Piranha bar!, and a box-blade, as well as a regular tilt-blade. BB does a great job of grooming trails, also pops rocks from the surface and collects them. I also got a landscape rake to help collect the jillions of sticks that always need clearing on wooded property. Also, if you're going to be removing and carting trees, pallet forks. Much more useful than I ever imagined.
/ First time tractor owner - soon #7
MikeR 2018
:welcome: to TBN i think the price is a little high but good luck with your search to find a better deal.
I requested the BH. I don't need it now, but it's 1K cheaper if bought with the tractor.
I need to get a LOT of small rocks and some sticks off the trail. Sounds line BB and rake would help me too.
No. I just got a riding mower for that. Occasionally, the pasture must be mowed but it is rough, so the bush hog can handle that.
/ First time tractor owner - soon #11
For final grooming of a trail. Set the BB level and just barely touching the ground but with the teeth down a few inches and it will pop the rocks up and collect them and also do final smoothing, without collecting a lot of dirt. I just drug them over to the creek bed.
Sounds good. Got'a get one. Thanks.
/ First time tractor owner - soon #13
You don't say were you are located, but I have seen the CK2610 TLB advertised for $23,900 + other implements. Look around for other prices, then compare. The 2610 is definitely more tractor.
/ First time tractor owner - soon #14
By the sounds you have done your home work :thumbsup:
I'm in Central Pa. Where have you seen that price?
I thought of the 2610. I like the larger lift capacity and weight. i don't like the wider, longer size. I have some tight spots to fit in. Although, I'd go to 2610 if the price is the same. Don't think it will be.
Mike
/ First time tractor owner - soon #17
Mike
I'm in NY, I just bought a ck3510se hst, from a dealer not too far from the PA border. I got it with FEL, BH, 60" brush hog, 60" box blade, and filled tires. I paid 30k. The 2510 is a smaller machine, without all of the options that the SE includes. Your price sounds quite high to me. Definitely shop around some more.
Ok, Thanks
I'm curious about the 'SE' models. What does 'SE' have that non-SE does not?
/ First time tractor owner - soon #20
The SE comes with most of the available options included. I can list what I remember, but it might not be everything.
Rubber floor mat
Tilt wheel
Cruise control
HST linked pedal
dual rear remotes
side mirrors
little plastic toolbox
telescoping lower 3pt arms
armrests on the seat
The difference at my dealer between the regular 3510 and the SE was only 1600 dollars. If you're getting a backhoe and need the rear remote, that alone almost makes it worth the SE package cost. Also, I plan on using the 2nd remote in the future for a grapple...I'll just need to get hoses made, and run them from the rear to the front. Cheaper than a true 3rd function kit.
2013 Nissan Versa Sedan (A64557)
2013 Nissan Versa...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
BUSH HOG SM60 DITCH BANK MOWER (A64278)
BUSH HOG SM60...
1995 Bulk 307 SS Insulated 6,500 Gallon T/A Chemical Tanker Trailer (A64194)
1995 Bulk 307 SS...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
