VroomVroom
- Joined
- Apr 30, 2010
- Messages
- 1,122
- Location
- Newfoundland
- Tractor
- Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Would a similar size diesel pull harder than a similar size gas tractor?
IF the engines are rated at the same HP and the drawbar HP is the same, they will pull the same. HP is HP is HP and torque is torque is torque. No exceptions.
So you have to start by comparing apples to apples.
Start with displacement. The diesels will typically have larger displacement than the gas of the same HP rating. And the diesels will have longer strokes. Those long connecting rods are longer levers to push the crank around. This means more torque.
Diesels have the advantage of being able to hold in a good torque range longer than the shorter stroke gas engines. That's what you want when pulling loads. If the engine starts to bog, it has a better chance of recovering and staying in the torque range. But, again, it's not comparing apples to apples due to the larger engine displacement and/or turbocharging.
The high compression ratio of a diesel keeps the power coming on. It’s a stark difference between a L2501 diesel at ~25:1 compared to a 6:1 compression ratio on a Ford 8N, both about 25hp.
.I agree that mathematically HP is HP and torque is torque, no exceptions.
However, I recently had the opportunity to bush hog very thick grass using both a 2017 L2501 HST and a 1952 Ford 8N back to back using the same mower on the same property. The L2501 performed drastically better than the 8N despite having less displacement, shorter stroke, less HP, and less torque. The diesel was able to maintain rpm much better than the 8N. It’d be interesting to know the reasons why?
Closest comparison I have is a JD 4010 and 4020...You can www tractor data site to see the specs. The 4010 was diesel and the 4020 was LP. The difference to me was night and day in several areas. I got just as much work done with the 10 as I did with the 20 with a whole lot less hassle and operator discomfort.
I started with gas tractors Farmall Super A and then IH 464, 1974 model I bought in '79 with several hundred hours on it, used as a bush hogger. The A was unique to low hp magneto driven units. The 464 was modern and equipped as such. I kept it for 5+ years and it was problematic for me, main problems were fuel associated and getting it to start in cold weather....yes getting it to start in cold weather. I did have a MF TO 20 that was a good gasser considering it's capabilities and later a MF 35 that was nice, but gas. I had a MF 35 Diesel also and it's torque curve peaked at 1000 rpm with PTO at 1600-1800 forget which. It was a super tugger, much more than the gas version.
As time went by I sold off the gassers and stayed with diesels. Not sorry. They just run, work, fuel is safe (for fuel), easy to get and use, plenty of power, torque and they will sit for a year and with a fresh battery fire right up, no fuel issues (but I use Power Services products just in case).
For me, it's diesels, hands down.....When's the last time you saw a piece of heavy construction equipment that was a gasser?????
Never had a diesel pickup truck. Never will. 1991 Ford 350 dually, 460 V8, 4 (OD) on the floor; Ram Hemi, 2009 5 sp. auto P/U......... ruined any chance of me ever having a diesel PU. The Ram solved the only problem I had with the Ford...old technology engine....loved the gas pumps but it could work as could the Ram. That Ford was the only stick shift vehicle I ever owned that you could dump the clutch at idle with a load and it just smiled at you.
Diesel doesn't go bad like gas does sitting
Yes it can...
Maybe if you bought it from standard oil. It can happen but it takes way longer.
Not tryin to start a war..... To do the work of a comparable diesel, your gassers gotta turn 3500-4500 rpms while the diesel is turning 1500-2500 rpm.
However, I recently had the opportunity to bush hog very thick grass using both a 2017 L2501 HST and a 1952 Ford 8N back to back using the same mower on the same property. The L2501 performed drastically better than the 8N despite having less displacement, shorter stroke, less HP, and less torque. The diesel was able to maintain rpm much better than the 8N. It壇 be interesting to know the reasons why?
