Is that repair still working? I ask because I bought a new E 170 this summer with the 48" deck on it. It was actually one that had been returned to Lowe's because somebody had left the owners manual on top of the engine, and it had caught fire. The damage from that had been repaired, so I bought it with 4 hours on it for over $1,000.00 off of the new price. Well, I'm having the same issue with the belt.
Right now it's got 34 hours on it, I've put two new belts on it, and had to put the belt back on several times. I was mowing some heavier grass last night, but it has thrown the belt off before with no warning for no reason that I could see. And it chews the belts up. I explained to my wife and son to start the blade at an idle, and that has helped make the belts last longer. The belt that is on it right now is still in fine shape. They are the K-force belts, they say they are the OEM belt.
At any rate, this morning I took a closer look at the pulleys. The tension pulley has quite a bit of play in it, both in the tension arm connection, and in the bearing itself. So, that might just be the problem. Also, I did not consider the deck pitch. I'll take a closer look at that. My Dad works for John Deere and I've asked him to look into the problem, but he hasn't gotten back with me, and as we moved two states away this summer, he has never seen the mower.
Thanks,
Jeff Carpenter
