Is this spool bad?
/ Is this spool bad?
Beezfun,
The attached circuit shows a possibly load holding option that would also allow the use of the "float" feature. It does require electrical signal to operate. Companies like Bucher, Hydro-Force, Delta Power, Rexroth - Oil Controls, etc. all make these Normally Closed solenoid operated valves. Just throwing out another possible option to help keep you confused :D
I think this is a nice solution. Found one on hydraulicstore.com for $61, plus some hoses and fittings.
/ Is this spool bad? #22
Was it one of the S2B valves? If yes that would be the correct valve. Would suggest the PB-S2B model for your flow rate.
Do not over torque the valve into the body or the coil nut. From memory around 30 ft-lbs on the valve & 5 ft-lbs on the coil nut. Over tightening can or will cause the valve to fail
It's this one. Flow rate is almost zero, there are flow restrictors in the line.
/ Is this spool bad? #24
Beezfun
That model might work since you have the flow restrictions. Problem is that it will not flow both directions when energized. In Delta Power model code that is an S2A
/ Is this spool bad? #25
I believe you, because I've left my front loader in the air for weeks and it doesn't drift down, so somebody made this valve that doesn't leak.
When the tail wheel is down and I'm mowing, it would be 78psi on the cylinder. If it's cantilevered out I agree it would be a lot more. But I don't care if it leaks down when it's cantilevered because I'm not mowing.
That's what I'm doing. But it's not just with the mower. If I'm trying to hold a back blade at a tilted angle and it leaks down/up this fast, I'll have to disconnect the hose then too. Not an impossible situation, but not what I expected.
I'm not sure what to tell you or suggest. All I know is that the problems that you have or figure that you are going to have are not a problem that I or my customers that have purchased valves from me seem to have. :confused3:
I say this because you mentioned if someone would have told you that these problems were always something that had to be dealt with, that you might not have invested in the "T&T".
These are not problems that everyone has to deal with. And before you figure that the Kubota valves are about the best there are, maybe the loader valves, but some of the current Kubota rear remote valves are among the worst ones out there among all of the tractor manufacturers. :(
Good luck with your decisions ahead of you. ;)
Beezfun
Yes, good catch. I need the S2B, or something equivalent.
/ Is this spool bad? #27
This is a contender for best thread of the year! :thumbsup:
Why wouldn't a toggle operated 2 way valve work for this? I don't need to move the cylinder up or down once I get it set, so I shut the toggle valve off. If I want to move the cylinder, or allow the float to work, I open the toggle valve. The only thing I really need from the toggle valve is positive shutoff with no leakage.
/ Is this spool bad? #30
Toggle valve would also work if you don稚 mind having to manually shift it.
I don't like adding anything with wires, they just end up getting torn off by low branches.
/ Is this spool bad? #32
Agree on the wires posing more potential problems. I was always amazed on how corn stalks could find their way into the darndest places.
So I went to the local hydraulics place and they suggested a miniature ball valve, which worked great. It's good for 2500psi, which is fine for my system. Only cost $4.50, cheapest hydraulic part I've ever bought.
2009 WESTERN STAR 4900 SF WINCH TRUCK (A67714)
2009 WESTERN STAR...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
JOHN DEERE 260E (A68134)
JOHN DEERE 260E...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
2013 CHEVROLET TAHOE (A66091)
2013 CHEVROLET...
