Toolcat 5610 F and 5610 G Series Pictures
   / Toolcat 5610 F and 5610 G Series Pictures #91
Are the newer 5610's like a 2017 a tier 4 that uses DEF fluid? Any issues?
:thumbsup: Post pictures when you get it.
   / Toolcat 5610 F and 5610 G Series Pictures #95
I'm hoping the 5610 can run my 5' cutter, tiller, and blower on the back. I'm getting a 72" finish mower for the front.
   / Toolcat 5610 F and 5610 G Series Pictures #96
I like the old MF too. Thanks again. Ya, I was just wondering if the rad flipped up to give more access to the engine. Like I said, I've seen them, but never looked at one up close.
I just got my new-to-me G series delivered. After going through the manual a few times (lots of stuff), I see that it does swing up a short amount. You hook a hoist to the specific points, remove 2 bolts on each side, loosen 1 pivot bolt on each side, lift until a bolt hole lines up on each side, install 2 of the bolts you removed.
   / Toolcat 5610 F and 5610 G Series Pictures #97
Even after looking through the manual, I cant figure out what the plastic knob is for that is midway up in the front door window. It looks like a latch to hold door or window open????
   / Toolcat 5610 F and 5610 G Series Pictures #98
the knob holds the rear window up against the front if you want more air flow through the cab.. you can uncouple the rear window from hardware fold forward and spin the knob on the front window to hold it up against it..
   / Toolcat 5610 F and 5610 G Series Pictures #99
Ahhh yes! Thank you! I seen in the manual they say that rear window is also the last resort exit if the doors don't open. Ha! I don't think I could fit too easily at my age!
   / Toolcat 5610 F and 5610 G Series Pictures #100
No issues with ours so far.
The G Series uses a Doosan diesel engine, no DEF and no DPF.
Details here: New Bobcat Toolcats | Living the Country Life
I just ran it for my dad inside the closed shed and am surprised at how clean it runs, even cold. His older Case 1390(David Brown) tractor would choke out even the toughest mosquitos after 60 seconds.
1993 UTILITY TRAILER MANUFACTURER 45 FLATBED T/A TRAILER (A58214)
1993 UTILITY...
Polaris Ranger (A56859)
Polaris Ranger...
2326 (A58376)
2326 (A58376)
2382 (A58376)
2382 (A58376)
TOOTHED BUCKET FOR MINI EXCAVATOR (A58216)
TOOTHED BUCKET FOR...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
