Buying Advice Done with hydrostatics
/ Done with hydrostatics #101
and as I have said what I i have been doing all this time is lock throttle to full AND push with travel pedal full down AS WELL until either the job gets done
I am slightly confused, I am assuming that this is in regards to your hydro riding mower/ lawn tractor, you are opening the hand throttle all the way (WOT) and then putting the hydro pedal all the way as far as it will go? If this is correct it sounds to me like you are trying to mow at the absolute maximum speed your mower is capable of, this would be the same as placing a geared unit in it's highest gear and WOT and expecting it to work well and last.
I am not a hydro fan by any means but I wouldn't expect much equipment to last very long being operated in that manner, gear driven or hydro.
I hope I have misread your operating style.
Go look at used garden tractors with the Tuff Torq K66 or the Hydro Gear G730. You'll be replacing engines before rear axles unless you are exceptionally hard on them or you are exceptionally unlucky.
I have a barely used complete mower lined up for $800 (don't know the make off hand) up but this issue will need to be either resolved or passed to a sub-process before I buy it. And it's only 48" which does make a difference to me. Another idea might be to find one of those 'better' units and cannibalize it onto the SLTX1054.
We operate under napoleonic civil code, not common law, apples and oranges. I know next to nothing in the field but the issue of 'reasonable expectation' is a central one according to what I've heard.
/ Done with hydrostatics #104
What exact model are you looking at? If you tell us that, we can find what rear axle it has so you'll know if it's good to go... Or another junker.
Brands don't mean much, Husqvarna, Cub and John Deere all make some with the K42/46 junk, but other models with a G730 or K66. My opinion is that the G730 is a step up from a K66, but in recent years you can get a K66 with differential lock while there is no such thing in the G730.
After starting I back the throttle out of the choke range and then use the pedal to establish a usable travel speed depending on the grass condition. This may be a crawl with tall grass or full speed with short grass and once I have bracketed to the ideal speed I lock that too. What I use as a guide are the engine and deck feedback sounds, if it starts to shudder then the speed has to come down, etc. exactly as it would have to with standard gearing except that with standard gear I'd have to shift down as well. There is no shifting down with a HST. If this be incorrect then I'd want to know where it is documented as being incorrect.
/ Done with hydrostatics #106
Your doing it correctly. Full throttle at all times while doing work. Modulate travel speed as required with the HST. I have a Husqvarna Fast cut that is designed to mow at full HST speeds, and it does a fabulous job at 6.5 mph. Unless the grass is not maintained, the bulk of my 3.5 acre yard area is mowed at full speed. I keep the blades sharp, the throttle full on and it cuts perfectly.
What exact model are you looking at? If you tell us that, we can find what rear axle it has so you'll know if it's good to go... Or another junker.[/QUOT]
It's a 'White' and it's a 48" 3-blade deck, that's all I know, plus the fact that it'll probably be sold by the time I go for it :-(
[QUOT]Brands don't mean much, Husqvarna, Cub and John Deere all make some with the K42/46 junk, but other models with a G730 or K66. My opinion is that the G730 is a step up from a K66, but in recent years you can get a K66 with differential lock while there is no such thing in the G730.
My subject HST is a 618-0427B, I don't know how that is known in the trade jargon.
/ Done with hydrostatics #108
I think you have the Cub Cadet mower deck part number. What's the model and brand of the actual tractor that your looking to purchase?
/ Done with hydrostatics #109
OK, that is what I would think most people do.
Your quote didn't read that way and I was wondering :confused3:
I only know that it's a White, 3-blade, 48", my son lined it up and apparently it's a good deal but being hardly used at all it's also likely to move faster than yours truly.
/ Done with hydrostatics #111
Your low end mower broke after 9 years. I hate it for you. You probably also get upset when your harbor freight ratchet strips in half the time it takes a snap on. Pony up and buy quality or quite complaining about low quality stuff.
It may have sounded frightful, because it *is* frightful running full tilt on short grass. The full speed is a handful and at times you gotta work pretty intensely to hang on to the steering :) Thing is, the machine has no feelings but it still seems to be cutting a swath in a regime that it feels very good in.
/ Done with hydrostatics #113
I still have a 2003 cub- cadet 1529 running well with a 19 HP Kawasaki, and hydro. The one thing I learn the hard way is lawn tractors with sealed hydro's don't pull anything. I burned up two prior to buying this one which now has 1600 hours on it and has never pushed or pulled anything but itself. It doesn't push snow, pull a lawn cart, roller, spreader, nothing, even though the owners manual said it can and implements are sold to fit it.
That is the only reason I believe it has lasted this long.
Not this boy. What I see is that I paid good money for a mower on which after only 300 hours there is still a very good engine because I had maintained it well, an excellent almost better than new deck because I have maintained and modified it over the years, like-new tires and the rest of a very long list that clearly establishes what *is* reasonably expectable for $3500 including tax. But it all bombed without warning for what could well be a major design fubar plus a 'maintenance-free' insult making the rest of the rig maybe intentionally prematurely unusable.
/ Done with hydrostatics #116
If that is the rear axle in the used tractor that you are looking to buy.... Run! Do not give $800 for a used tractor with that POS in it.
For $800 you can find a pretty dang decent garden tractor with a K66 or G730. That is not a tractor that you want to own.
hehe, I think it's the MTD label of the one I do own....
/ Done with hydrostatics #118
If that is the case... Then I understand why it met it's demise at sub-300 hours. That's about equal to the rear axle in a 12V Barbie Jeep
you mean like we used to call the BA-146 the Fisher-Price Galaxy :)
/ Done with hydrostatics #120
So the subject trans of this thread is a $ 300 MTD transaxle? Not a tuff Torque K46?
Seems like You can just get the new transaxle for another 300 hours So $1 an hour run time other than R&R on a $3500 mower Could be worse No?
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2014 Chevrolet Impala Limited Sedan (A66738)
2014 Chevrolet...
CAT C1.1 LITER WITH GEN END (CONDITION UNKNOWN) (A67714)
CAT C1.1 LITER...
PALLET OF FUEL TANK AND TOOLBOXES (A68842)
PALLET OF FUEL...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
2025 16in Tooth Bucket Mini Excavator Attachment (A66734)
2025 16in Tooth...
