New Holland TC35 PTO
   / New Holland TC35 PTO #1
RARA
new Holland tc35a
Hello all,
I have a 2003 NH TC35P or that is what the tag shows NH stated that they never made a TC35P that it is a TC35P, okay so on to the question have had no problems with this unit till now, the PTO will not engage the light comes on but no rotation does this unit have a some sort of electrical safety or fuse?
   / New Holland TC35 PTO #2
Hello all,
If your tractor has an independent PTO (see your operator's manual), there is a hydraulically actuated clutch that engages the pto shaft to supply power. Either the pressure line is leaking, the valves is not working or the pto clutch is worn.
Jerry,
thanks I will check that out. The unit I have has a single lever to the left of the operator that rotates a shaft in small Hydraulic valve.
What I find odd is was the bush hog was on and working put hay fork on the switched back to the bush hog and the PTO was dead just all at once.
all the other hydraulics on the tractor work fine.
thanks.
197359 (A50458)
197359 (A50458)
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
1272 (A50490)
1272 (A50490)
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
