New Holland TC35 PTO
   / New Holland TC35 PTO #1
RARA
new Holland tc35a
Hello all,
I have a 2003 NH TC35P or that is what the tag shows NH stated that they never made a TC35P that it is a TC35P, okay so on to the question have had no problems with this unit till now, the PTO will not engage the light comes on but no rotation does this unit have a some sort of electrical safety or fuse?
   / New Holland TC35 PTO #2
Hello all,
If your tractor has an independent PTO (see your operator's manual), there is a hydraulically actuated clutch that engages the pto shaft to supply power. Either the pressure line is leaking, the valves is not working or the pto clutch is worn.
Jerry,
thanks I will check that out. The unit I have has a single lever to the left of the operator that rotates a shaft in small Hydraulic valve.
What I find odd is was the bush hog was on and working put hay fork on the switched back to the bush hog and the PTO was dead just all at once.
all the other hydraulics on the tractor work fine.
thanks.
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
Adams 8 Ton Weigh Hopper (A52128)
Adams 8 Ton Weigh...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
Unused Delta Crash...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
