Basic info
/ Basic info #1
kjg26
Buford, GA
2013 Kioti DK55
Is there any resource on the internet with basic info on maintenance on these tractors? How to check fuel bowl, how to do oil and hydraulic changes, how to disconnect loader, where and what to grease, how to's in general. I am a brand new tractor owner with a new to me 2013 DK55.
I have never owned a tractor before. I am taking it slow and being careful. I want to be able to keep this thing in the best shape possible but am having to learn along the way without any guidance.
I ask this as I am trying to trouble shoot a strange vibrating/humming sound from one of the loader roll hydraulic lines. I've isolated which line it is but don't know where to go from there.
It was suggested in the hydraulic forum that there may be air in the line and that i should cycle the loader, disconnect the QD and reconnect. Then possible do the same with the loader up in the air. As i'm new to tractors and don't understand how they work entirely it makes me nervous to disconnect a pressure line while the loader is up in the air.
Sorry for the rambling...just trying to get an understanding and guidance.
/ Basic info #2
Have you check hyd.level and what are you running for RPM's for starters.
/ Basic info
Rpm is at the marked pto rate. I want to say 2400. Hydraulic level was fine.
/ Basic info #6
That "N" serial number is indeed the 2013 build year. The next three digits (068) indicate a straight DK55 (not SE). I think this may also be called a 551 model. The DK55 is very similar to the DK45 except for the turbocharged engine.
/ Basic info
Yes its a 551. The manual says that. What is the diff between a 551 and a 55se?
/ Basic info #8
I sent you a private message. In my opinion, the 451/551 models were better, stronger designs. I have a 451 (aka DK45s) so I'm biased. I think the SE models were designed to reduce cost. For example, the 551 has a planetary final drive vs a simple 2-gear final drive. In 2005 Kioti changed to a new engine (with stop solenoid on front, same engine as EX and SE models) and some of the manuals still show the old engine (stop solenoid on right side).
/ Basic info
Thank you for the PM. I'm currently reading over the owner's manual line by line. Sadly use tractor is an hour and a 1/2 away from me and just run out and take a look at it. Plan is to be out there tomorrow and/or Monday
/ Basic info #10
Search tractor by net or post questions. All the information you could ever need is right here
/ Basic info #12
Hydraulics can drive you nuts sometimes. Get a slight kink in a line, defect in a connector, a piece of trash in the line and they can dance like mad. You might try using a big zip tie and fastening the line to the frame where ever you can to see if that helps. Might be something small that starts a resonance. Other things it could be is a slight internal leak in a cylinder or a control valve not closing all the way (check the adjustment of the loader valves for the joystick). I would not panic on this one.
/ Basic info
Can you explain how thats done? The adjustments. Im reading owners manual now
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Toro Workman HDX-D Utility Cart (A61567)
Toro Workman HDX-D...
2005 John Deere 7320 (A60462)
2005 John Deere...
2025 Spirit Electric Scooter (A61569)
2025 Spirit...
1996 Geo Tracker SUV (A60352)
1996 Geo Tracker...
LandHonor LHR-SL2T3M 2-Ton Chain Hoist (A60352)
LandHonor...
