MF vs Kubota Sub Compacts
/ MF vs Kubota Sub Compacts #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I saw some MF subcompact prices and financing options which looked more attractive than Kubota BX's.
What are the major differences between the 2 mfrs? Is the BX worth paying more for?
I am shopping for 24 to 25 hp, quick attach loader & bucket, snow plow, and 54" to 60" mmm.
TIA
Yooper Dave
/ MF vs Kubota Sub Compacts #2
The driveline is essentially the same. Kubota makes their own motor, MF uses Iseki. Go look at the 2 of them, operate and compare. Decide which one you prefer. Buy it.
IMHO, I didn't like Kub's pedal setup. I thought their loader frame was too light duty, thin steel, you can't open the hood with the brush guard in place, and it was over a grand more money.
/ MF vs Kubota Sub Compacts #3
TIA
Yooper Dave
The whole GC line is actually an Iseki built Tractor from Japan, powertrain and frame. The best sourced “MF” in their line-up in my opinion. The loader and hoe are US built in Tennessee, the company name is eluding me this moment, but a top quality mfr’r. You should be able to get the GC for thousands less. 5 year powertrain warranty.
/ MF vs Kubota Sub Compacts #4
check out the kioti's. lots cheaper than kubota, more features standard, options are half the price or less. 6 year warranty.
/ MF vs Kubota Sub Compacts #5
I did the same shopping a few years ago. It seem a bit of an oddity that the bucket for the BX is operated by just a single hydraulic cylinder in the center. The Massey uses a hydraulic ram on each side of the bucket, which is a more traditional approach that you see very commonly applied to tractors.
Good luck with your choice. My little GC1710 is a workhorse that has performed very well.
/ MF vs Kubota Sub Compacts #6
I had the previous model GC2310 at one time. Excellent scut for power of FEL and BH along with design. 3pt could stay on tractor with BH attached. Outriggers straight up in vertical position with excellent "feet" design.
I don't know if it has changed with newer models, but damage to the dreaded scut hydro cooling fan was a twenty minute job on the Massey and an engine move on the Kubota. Some members at the time came up with some modified fixes...or under body armor.
As pointed out, check both out and decide what's best for you.
/ MF vs Kubota Sub Compacts #7
I have a GC1720 and so far it's been a good machine. The price difference is what made the decision between Kubota and MF. I also looked at Kioti and they also are good machines but I did not like the local dealer.
Kioti and Kubota have the advantage of being made completely by their respective companies. The MF is sort of a kluged together collection of Japanese, US and Chinese parts. The loader bucket and subframe and backhoe subframe all have Made in PRC labels on them. The hydraulic cylinders also have no mfr info at all and I suspect they are also Chinese origin.
Had I known about all the Chinese parts on my MF it probably would have swung me to Kioti regardless of whether I liked the dealer or not. The Chinese parts appear to be good quality and the tractor has done everything I have e asked of it. I just have an issue with sending so much of my money to a country that is not our friend and uses ridiculous labor practices - do not want this to turn into a political discussion.
/ MF vs Kubota Sub Compacts #8
At the time, my 2310 was of complete Japanese manufacture. I did read a post on this site that John Deere was even using China as supplier for an FEL on one, if not more, of their small tractors. So that is a concern, which you addressed well on the new machines but not surprising.
/ MF vs Kubota Sub Compacts #9
TIA
Yooper Dave
The only sound advice anyone can give you on your purchase is to test drive each one. I tested out the JD, MF, Kubota, Simplicity, Bobcat, Kioti, LS, Cub Cadet, Mahindrah. Compared features and reliability, warranty financing and dealership. Chose the GC2410 and never regretted it. There are so many pros and cons to each but...in the end the test drive sold me.
/ MF vs Kubota Sub Compacts #10
Bobcat has used single cylinder rams for years on the dump!!! MF still has grease fittings on the top ends of the lower pivot which went out about twenty years ago from the high maintenance of having to replace them when broken instead of on the end of the cylinder pin like most all name brands do today!
/ MF vs Kubota Sub Compacts #11
My wood splitter has a single ram and works great. But the question being asked was to ask about differences between a Kubota BX and a Massey GC. One ram vs two is an accurate difference, yes?
/ MF vs Kubota Sub Compacts #12
My kioti has 2 rams..can can lift 1800 lbs, breakout force is 3400 if I recall. Bigger tractors have bigger numbers.
So in theory then ONE ram can do half that, 1 bigger ram can do more.
And would perhaps be half the price/parts.
One I guess can question who makes the ultimate decision - the bean counters (make it cheaper), the warranty cost folks (don't let it break), the engineers (make it bigger and stronger), etc.
For lower cost you only have so many options - a more efficient company, larger production capacity to reduce per unit cost, cheaper parts (source, manufacture, etc), smoke and mirrors - EVERYone is offering 6, 7 or more years with no interest...money isn't free, so they'r emaking their money in there somewhere.
Just saw an ad on TV for Kubota, L3301 I think, $129/mo. OK, no loader, DT model, 7 years. Possible, sure - but is that the tractor you actually want, feature wise?
the TYM/Rural King are nice as they are fully equipped right out of the gate - but after sale service? Maybe the company knows it won't have that (cost) so they can make the machine better?
So many variables it's hard to say what to get.
/ MF vs Kubota Sub Compacts #13
I compared the two you are looking at. Went with Massey GC1705 for several reasons. GC1705 outspec'd Kubota on features important to me. Rear PTO HP on the massey is close to 19hp with the engine running at only 2600rpm. Kubota has to run wide open at 3000rpm to hit its rated numbers. Loader operation is also painfully slow with the kubota unless running at high RPM. Ergonomics and operator platform were better on the massey. Drive over MMM on the massey is straightforward, no ramps and transforming needed like the kubota.
What Kubota has going for it are some convenience features like the tilt steering wheel, single lever loader hydraulic detach from the manifold, quick attach for the loader bucket. Honestly you have several quick attach options for the loader bucket with Massey. They are not expensive and your dealer can probably package it with the machine. You will fine Massey is better prices than the Kubota too.
/ MF vs Kubota Sub Compacts #14
I didn’t try negotiating price with the Kubota dealer but their asking price was about 20% higher than the equivalent MF. That right there was what made the decision for me. There is probably an element of you get what you pay for but so far I’ve been happy with my MF.
/ MF vs Kubota Sub Compacts #15
TIA
Yooper Dave
Yooper,
There should be a great number of threads on TBN comparing kubota BX product to Massey gc1700 product, I've written a number of them.
There is nothing like researching to verify opinions you'll read. Some import things to remember in my opinion:
Know the best engine makers for scuts and the best ones have a 30 year history each of making engines for scuts and long term agreements. Both Iseki and kubota fall in that category.
Know which engine makers actually build the tractors those engines go in. Again Iseki and kubota are that category.
Those many threads of 2015 and 2016 and 2017 will summarize for you all the specifics and why they are important.
Know the fit and feel of each brand you are considering.
After reading a dozen threads or maybe two dozen threads of BX. Vs GC threads, you'll have much more awareness than some of the salespeople you will encounter.
/ MF vs Kubota Sub Compacts #16
TIA
Yooper Dave
Here's a thought from someone that just took delivery of a GC1700 series tractor ....
Before you pull the trigger on either one, check what the "full package" will cost you in the end. By full package, I'm talking what the tractor and any extras will cost you. Think of the extras as implements you will reasonably expect to add in the end. Are they compatible with the unit you buy? What extras will you need to make the tractor set-up you want in the end cost?
I planned on basically wanting a quick hitch (QH) on the front that I would switch between FEL to pallet forks. Never thought of looking this far out before purchaseing and thinking it would be a "standard" thing MF would have. Now, after getting the tractor, I fing that MF has a reasonable priced QH but sell no forks that are compatible! The only work around (no, not going with clamp-on to FEL) is to buy a set of customized QH by seperate company that charges $$$$ (about 3x more) for a QH that will do both the FEL and their forks. Yep, then you have to only use their compatible implements. Well made and quality built - no doubt from what I read - still not what I expected.
I don't know, but maybe the BX has a better system for QH with cheaper implements used to work together in the end. More up front for the tractor but maybe less in the end for the "full package" you expect to have. I don't know if I made a mistake but I admit - as much research as I did on tractor - I should have done more in the end on a "full package."
Just a thought. Good luck in your search.
/ MF vs Kubota Sub Compacts #17
Yooper,
So I've noticed that you started this thread but then really haven't returned to ask questions or describe your efforts.
Although there are similarities in many ways between the GC products and the BX products. . . there are also a few important differences. 2 pumps versus 1 pump, differences in fel payload capacity, cockpit fits and control pedals, fel coupler methods and selection of mower decks and of course pricing to name just a few.
Engine quality and engine/tractor compatibility are strong points for both brands.
And if you are doing a quick attach process for your fel to drop a bucket and add forks or other bucks, it's important to check with 3rd party vendors too. . . like MyTractorTools.com.
A friend of mine bought a kubota B2601 with a 60 inch bucket. Then he decided he wanted quick attach . . . So the dealer switched to the same size bucket with the quick attach feature . . . but it was another 650.00 plus tax (no uncharge for switching just the difference in costs of the buckets) . My friend hadn't done his homework but was smart enough to know to get what he wants and needs to see his new unit as a long term benefit.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
More info coming soon (A61574)
More info coming...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
RoGator RG1100C (A63688)
RoGator RG1100C...
