Is this supposed to happen?
/ Is this supposed to happen? #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
I recently typed in invest in another thread and a link to a bitcoin site was automatically inserted. Is this supposed to happen?
Steve
Edit
Now typing in the "b" word inserts a link.:shocked:
/ Is this supposed to happen? #2
Bitcoin
didn't seem to do it for me.
Bitcoin
It did for me.:)
If it makes any difference, I am using Chrome on a Chromebook.
Steve
/ Is this supposed to happen? #4
Invest
Testing, testing....123
Nope....doesn't do it for me. I have seen the word "Kubota" changed into a link before.
/ Is this supposed to happen? #5
Invest
Kubota
Stonypoint
Nope..
Not on the android app
/ Is this supposed to happen? #6
The only link in this thread I see is the "kubota" one. Using Chrome on Windows.
/ Is this supposed to happen? #7
Steve
Edit
Surely you must have some sort of chart that explains this ? Lol
/ Is this supposed to happen? #8
Maybe this is the setting choice causing some to get the link and some not.
My Home-General Settings-Miscellaneous Options-Forum Skin.
Bruce
Bruce
I'm using "Tractor" and have been doing so for what seems ages. I think I have used the i***** word before without a link being created.:confused3:
Steve
When it comes to the topic of this thread, I am at the origin in this graph of the Dunning-Kruger effect -- I have no expertise in the topic and I know it.
Steve
I shutdown my Chromebook for an update. After restarting, the invest link has disappeared from my original message, but the bitcoin link remains.:confused3:
Steve
EDIT Oh no!!!! The invest link has now reappeared in post #1 and this post.:shocked:
EDIT 2. It's disappeared again. I'm beginning to think the i***** word is associated with quantum physics -- observation changes its behavior.
EDIT 3 Note to self -- never again use the i***** word in a TBN post.
/ Is this supposed to happen? #14
So, is the Chromebook system causing the problem?
Steve
Now that I come back to this thread, I see that the two test words that I posted have changed into links on my machine as well. I do not have Chromebook.
Very strange.................or maybe not. My knowledge of these types of things is very limited :)
That makes two of us. My knowledge of these types of things is at its lower bound -- zero.:)
I don't have any problems with the links as long as TBN's ownership stands to make money from their presence.
Steve
/ Is this supposed to happen? #16
FWIW...
Some of these hyperlinks like the K_ubota ones are created by a script running on this site...the others are created by google and their invasive browser and O/S...!
FWIW...
Is there any way to tell which is which?
Steve
/ Is this supposed to happen? #18
Steve
If the links are known sponsors/advertisers of TBN...it's reasonable to assume they are created by TBN i.e., K_ubota etc...
on a similar note...
If your Chrome (google) book has voice search capability enabled...it is always listening even when you are not searching for anything...and will display advertisements related to whatever it hears...
/ Is this supposed to happen? #19
Steve
Its probably a malicious extension, can you post a screenshot of the installed extensions?
https://support.google.com/chromebook/answer/2589434?hl=en said:
To remove an app or extension from your Chromebook, follow the steps below.
Uninstall an extension
Open Chrome.
Click More More and then More tools and then Extensions.
Next to the extension you want to remove, click Remove Remove an extension from Chrome.
To confirm, click Remove.
Tip: To remove an extension that's a button on the browser toolbar, right-click the button and select Remove from Chrome.
Disable an extension
To temporarily stop using an extension:
Open Chrome.
Next to the extension you want to disable, uncheck the box next to Enabled.
FWIW...
In this case, I would suspect a malicious extension rather than Chrome.
Aaron Z
/ Is this supposed to happen? #20
FWIW...look at the page source code for the original post and look at line 1144...see the word "autolink"
The script is hard coded into the forum software (likely a part of google advertising applications)
I would call it invasive, not necessarily malicious...but then again anything that google (and accepted third party apps) does is invasive...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
6' Bush Hog (A62613)
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
John Deere 50 (A60462)
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
