3-Point Hitch PTO connect brush mower to JD3046R
   / PTO connect brush mower to JD3046R #11
I have the problem w my tiller. The bush hog not so much. Both have the pin to push in not the collar. Both are 2 years old.
I have found the more wd-40 I use the easier it is. Also make sure the pto shaft is well oiled so it is easy to slide in/out.
Getting the splines lined up perfectly seems like part voodoo sometimes.
   / PTO connect brush mower to JD3046R #12
I would suggest wire brushing the beans out of that PTO shaft,grease and cover when not in use.WD 40 also will help on the female side.
   / PTO connect brush mower to JD3046R #13
Clean it up for cryin out loud, tolerances don't account for rust!
   / PTO connect brush mower to JD3046R #14
Personally I see possible problem with rust on shaft if it is correct picture in thread.... I would clean shaft extremely well and coat with heavy grease, and when not is use cover with something to protect it from dirt and rust ... Clamp a section of hose over it?....This is a semi precision fit, RUST destroys the precision....
Dale
I use fluid film once in a while on the shaft, but the most important thing is keeping it clean and rust free.
   / PTO connect brush mower to JD3046R #15
And while we're on the subject of grease, white lithium grease has no business on a farm. Use the 3% molybdenum grease, whatever the color, for effective lubrication on your PTO spline and telescoping shaft.
   / PTO connect brush mower to JD3046R #16
I have been using 3 in 1 oil on the telescoping shaft. Is that not sufficient? Also I hit the male spline with WD40 as well as the female side and the push button. Seems to keep everything in shape. Also tractor and hog are stored inside.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
3650 (A47477)
3650 (A47477)
E-Z Trail 700 bu Auger Wagon (A59814)
E-Z Trail 700 bu...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
