Mower bolt problem
/ Mower bolt problem #1
dodge man
Super Star Member
West central Illinois
JD 2025R
In another thread I talked about my blade style problem but I encountered another one when I put new blades on yesterday.
It is a 60 deck on a BX2350. One blade bolt was badly damaged when I swapped blades. It came out really hard. Probably took 3 minutes with an impact. About just the last half inch of threads were badly tore up, almost looking worn down. I got a new blade bolt and ran a tap up in the hole. It did a lot of cutting, which I expected. The last part of it cut really hard, which is probably where the damaged part of the bolt was. It then seemed to tighten up fine.
Questions? What caused it? I don not think the bolt was loose before I took the blade off but I am not positive. I install the bolts by hand almost all the way to engage the hex washer, then tighten with an impact.
Should I expect problems again? Can you replace just the shaft or would I need an entire spindle assembly?
/ Mower bolt problem #2
There might have been gunk in the threads at the bottom.
I would only replace it if it gives you issues, such as it loosening up.
You could tap it next size up or two as well.
/ Mower bolt problem #3
......................What caused it? I don not think the bolt was loose before I took the blade off but I am not positive. I install the bolts by hand almost all the way to engage the hex washer, then tighten with an impact....................................Should I expect problems again?...................................
It could be that tightening with the impact was overdone, and the threads became galled or partially stripped. It doesn't take a lot of force to tighten the bolts. I have used my 1/4" impact on my 72" RFM and haven't spun a blade.
If that's the case and they were overtightened, it will happen again.
It’s possible it was over tightened. I’ve had them come loose before so I hit them pretty good.
/ Mower bolt problem #6
Do not care about the rules but I put a coat of silver anti seize every time and just use the 3/4 inch socket bar to loosen and tighten using a 2x4 block for bracing the blade, grass juice here is corrosive and always gives me problems on untreated fasteners around here. Makes it much easier to remove every time just do not over torque with the impact wrench.
David
/ Mower bolt problem #7
David
I had been doing exactly the same for years accept I used a 1/2" breaker bar and socket. Never had a problem.
However now I replaced the breaker bar with a 20v 3/8" impact gun and don't need to block the blades with a piece of 2x4. I just let up on the trigger without doing a lot of hammering when torquing the bolts.
Older and wiser...............;)
/ Mower bolt problem #8
I have had too many bolts with screwed up threads caused by impact guns, always break them loose by hand and like to thread them back in by hand so I can feel for any problem spots if I need to use the thread chaser kit I have or the thread pitch files I have to keep things from seizing up.
Sometimes being patient is being wise also.
David
/ Mower bolt problem #9
What David said. I also paint mine with anti-seize and (so far...) haven't had one loosen. Off and on by hand + bar and big socket.
I'm extra paranoid from being around boats. Stainless in stainless and you get some galling when being too enthusiastic - and it's game over.
Z.
/ Mower bolt problem #10
You got that right! I worked around a lot of heavy industrial equipment made with all types of stainless steel alloys due to the corrosive materials in that industry. Nothing was bolted or screwed together without a coating of Never-Seez NSBT-16N Silver Pure Nickel Special Anti-Seize Compound on the threads.
/ Mower bolt problem #11
Don't use an impact gun to tighten the blades, invest in a torque wrench and use the proper torque. I ruined a spindle on my Landpride 72 inch by using an impact gun. No more. Of course use anti-seize like the others recommended also. The finer the thread pitch the easier it is to damage the threads, I'm guessing the thread is metric and if I know the Japs I'd say 1.25mm pitch which is easy to damage.
Good luck, Fred
/ Mower bolt problem #13
A friend was just showing me his thread chaser sets. He says NOT to use taps or Dies to repair damaged threads as you just make a mess of it. Just sayin! I would use a tap or die, as I don't have that luxury or if it was an expensive thing, take it to him!
I have a torque wrench. To be honest it is awkward to use so I am just being lazy. When I take the deck off it would be easy but normally I lift the front end up with the end loader to sharpen blades and there is not a lot of room to work.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
John Deere Z960M Zero Turn Mower (A64047)
John Deere Z960M...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
