Looking for a drag harrow.
/ Looking for a drag harrow. #1
jmt1271
MO
Kubota L2501
Buying a Kubota L2501 and am considering the LP drag harrow and not sure if it's the best option.
Main use is spreading manure around 3 acres of horse pasture and general pasture maintenance and preparing sections of my yard for over seeding this fall.
Looking at the LP because it's easy to just buy everything all at once from Kubota but don't want to overpay if there are better options. Thanks.
/ Looking for a drag harrow. #2
I was considering a drag harrow and looked into it a little. Northern tool has one that's relatively cheap. And there are others around. I'd think that if you bought it at the same time you bought the tractor maybe they'd give you a good price but you're going to be paying for the LP brand name IMO.
/ Looking for a drag harrow. #3
Also included in that price is LP quality. ;)
Unless the quality changed in the last several years.
/ Looking for a drag harrow. #4
That looks like something you could fabricate. My neighbor made one with chain link fence and pieces of old chain.
/ Looking for a drag harrow. #5
Dragging is ground contact work. In all ground contact work implement weight is your friend.
Consider "chain" diameter. Most are 3/8" diameter, 1/2" is heavier and probably optimum.
Make sure any chain harrow you consider has solidly attached drawbars at both ends of the harrow.
When considering Drag Harrow price, consider both cost per pound and cost per square foot. You will make a better decision.
Premium USA manufactured Drag Harrows sized for CUTS come from Wingfield. Wingfield's articles under HARROW INFORMATION are worth your time to read.
LINK: Wingfield American Drag Harrows
/ Looking for a drag harrow. #6
Premium USA manufactured Drag Harrows sized for CUTS come from Winfield. Winfield's articles under HARROW INFORMATION are worth your time to read.
80 bucks for the second end though. I'll bet that I can make one up for a lot less than that.
/ Looking for a drag harrow. #7
I agree weight is key. When dragging the pasture I wish mine was heavier. Likely will throw some concrete block on it.
I just bought one from tsc. Make sure it can fit through your gates!
/ Looking for a drag harrow. #8
I bet so too, especially if you know someone with chain link fence scrap...you could easily weight it. A couple old railroad ties?
/ Looking for a drag harrow. #9
I bought the Loyal harrow from TSC last year. Had to go south of the border, that's how much I wanted that particular one. It has two sections and one can mix and match, tines agressive, not agessive, or upside down. It had more tines for that small size, than other models. But it is a pain to flip over and around. Heavy and seems to be good quality.
It goes behind my Steiner, so I only wanted a 6 foot width.
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
