Has anyone had a hydrostatic transmission slip into Neutral on a hill?
I thought one thing we figured out here was that hydrostatic transmissions don't have neutral.  Seems like you can look at them like a speed control, (and zero is a speed, which they will attempt to meet), or just look at it for what it is, an infinitely variable transmission system that cannot be taken out of gear.  Of course, it's true that some hydrostatic transmissions have a gearbox connected to them.  And it's common to call the whole assembly between the engine the rear axle a transmission.  But this is really a hydrostatic transmission
plus a gear box.  And while virtually all gear boxes have neutral, a HST does not.
What are the takeaways here?
-If you have a tractor that has a HST, and no brakes, always keep the drive train in top shape.  Failure of a coupling, or a hose, could have you sailing down a hill.
-Terramites have a parking brake, keep it working.   Although it might not be the best way to stop a runaway, it's better than nothing.
-If you do have a gearbox somewhere in your drivetrain, don't disconnect your your drive train on a hill.  (Neutral)
