MF loader cap plate leak
/ MF loader cap plate leak #1
merlintractor
Colorado Front Range
MF 1260
I've sprung a leak at the joystick cap plate on my MF loader. My plan is to remove the plate, clean the surfaces and reseal with blue RTV. My question is, how much do I torque down the three retaining bolts? This my first DIY hydraulic repair...not my strong suit. Any advice appreciated.
/ MF loader cap plate leak #2
Post some pics, I'm not sure RTV is the way to go with this.
/ MF loader cap plate leak #4
That seal, and the orings on the spool, are low pressure seals. The high pressure seal is provided by the machined surface of the spool. So if you've got a constant source of leaking oil, it's likely the spool is scored or damaged. With the cap off you can probably figure out which spool is leaking, then you can pull that one and inspect it. It's also possible the valve body has been distorted if its mounting configuration or tightness has been changed in some way.
Ok, thx! I'll pull the cap plate and see what I can find.
2015 PETERBILT 389 (A67714)
2015 PETERBILT 389...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
2016 Ford Expedition SUV (A66738)
2016 Ford...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
2023 Dodge Durango AWD SUV (A66738)
2023 Dodge Durango...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
