I was told it is a bad idea...hold my beer!
   / I was told it is a bad idea...hold my beer! #71
This might be what some of you are describing (except for my predicament):
   / I was told it is a bad idea...hold my beer! #72
Very well designed roadway!!!
   / I was told it is a bad idea...hold my beer! #73
Google "forest road water diversion" and peruse some of the diverse options. Water bars are common; some provincial forest roads here have installed water diverter troughs that are effectively wooden, open-topped culverts made of two parallel PT 2X8 or 2X10. I'd worry about something like that getting clogged with debris...but I guess pretty much any solution will require some maintenance. Plus, a really big storm can overwhelm almost anything you do and cause a serious wash-out...hopefully, only very infrequently, though!
Good stuff!
Back ditch is doing well....but it is all shale...most of the gullies end here.
Front ditch is rutting bad.....always did... I just accelerated it by starting my trail up in the 1 gully that feeds it.20180612_182452.jpeg20180612_182457.jpeg20180612_182525.jpeg
   / I was told it is a bad idea...hold my beer! #76
Front ditch is rutting bad.....always did... I just accelerated it by starting my trail up in the 1 gully that feeds it.View attachment 558231View attachment 558232View attachment 558233
I'd get that water out of a shallow ditch before it gets anywhere near your shed. If you get any significant water in that ditch, your shed could be washed out or at least everything inside is at risk. That, or build a berm which will clearly protect that back of that shed from a gully-washer.
The ditch behind my 3 barns doesn't look deep enough or angled enough....but it truly moves a lot of water quick. For reference the barn with the tree down beside it has 14 foot high walls.
   / I was told it is a bad idea...hold my beer! #78
Water is amazing stuff. We just had a 3" rain northeast of here that overran a road and washed 6' of dirt off half a dozen vaults in a cemetery in a matter of minutes.
   / I was told it is a bad idea...hold my beer! #79
Had that same storm here last night, we were on one of the Lake Erie islands, caught the last ferry at 10 pm. That rain was a rain of biblical proportions. Couldn't tell where the lake ended and the sky began.
   / I was told it is a bad idea...hold my beer! #80
That storm was weird. It just sat there and spun like a small tropical storm and took several hours to move away, all the while dumping rain.
2006 S/A Dry Van Trailer (A55788)
2006 S/A Dry Van...
2015 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
2002 International 4300 DT466 (A53314)
2002 International...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
