Uncomfortable noise on finish mower
   / Uncomfortable noise on finish mower #11
Yes, since your mower floats on the the ground and is behind what the tractor is running over, there is going to be differences in the two U-joint angles.
Take a look at the video and imagine your tractor is one end of the PTO shaft and your mower gearbox is on the other end and see what is causing the vibrations. All you can do is try to minimize those differences when mowing.
Driveshaft Angle and Phasing - YouTube
It seems to me that as long as the system is properly set up, there should be no change in angle regardless of the height difference between Input and Output. And it seems to me that this would be one of the primary motivators for a slip joint in the PTO shaft - to allow the length to change as the implement ascends and descends.
Or, ASCII reference:
   / Uncomfortable noise on finish mower #13
It's not the length of the shaft but the angle of the joints. If you raise or lower the 3 point too much the ujoints will come into contact and create noise/issues. (Highlighted in attached drawing)
   / Uncomfortable noise on finish mower #14
There is definitely no mechanical interference.
I believe the stated probable issue is a difference in angle of input and output shaft. They should be at 180°. I believe they are in normal operation. When the mower is lifted, that may change, although it shouldn't IMO if things are properly engineered.
Yes, that is what I'm talking about. I don't believe that is the case. I know for sure that in normal operating mode they are both pretty near if not 100% (within normal person's measuring ability) dead level.
Lifting the 3-pt shouldn't IMO change the angle, although it may.
   / Uncomfortable noise on finish mower #17
Lifting the 3-pt shouldn't IMO change the angle, although it may.[/QUOTE
That's wonderful if that's not what is happening.
I'm curious how you have your top link adjusted because when it is correct, the rear of the mower does droop down when you raise the three point hitch. Do you think that maybe the issue?
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
2006 Gehl RS5-34 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2006 Gehl RS5-34...
2015 Peterbilt 320 Trash Truck (A55973)
2015 Peterbilt 320...
HOSHIZAKI ICE MAKER & ICE STORAGE BIN (A57192)
HOSHIZAKI ICE...
2019 CHEVROLET SILVERADO 11FT FLATBED (A57880)
2019 CHEVROLET...
2009 Honda Pilot SUV (A55853)
2009 Honda Pilot...
