Uncomfortable noise on finish mower
   / Uncomfortable noise on finish mower #1
dnw64
SE Vermont, South Jersey
Kubota B3030 Cab
I recently bought a used Land Pride FDR1660 finish mower.
It seems to operate nice when relatively flat, but if you lift the deck while it's operating, or go into a bit of a gulley that lifts it on the 3pt it makes a noise/feeling that something isn't right. It's not real lout, but kind of a rumble, or low growl.
I had to get a new PTO shaft for it, so my first thought was that I hadn't shortened it enough, but after double-checking, I still have 3-4" of play when fully raised.
I then checked the gearbox oil - clean and clear and within the min/max lines on the dipstick.
I put a hand on each of the three blades and yanked them about, and all the bearings seem normal.
Anything I should look further into, or is that an accepted factor of one of these mowers?
   / Uncomfortable noise on finish mower #2
IS the noise when the pto is at sharp angle? Are the yokes in line? Most newer shafts won't even allow you to misalign the yokes. Although most pto noise is a vibration or shudder, not so much a rumble.
Beyond that, it makes no sense that the noise is position dependent. The only thing changing is your pto shaft.
   / Uncomfortable noise on finish mower #3
It could be that what you are mowing is muffling the machine noise... but I.T. seems to have a better thing to check first.
   / Uncomfortable noise on finish mower #4
I would say the issue is in the PTO drive shaft yokes. Either failing or phasing.
Most drive shafts are designed so that they can't be assembled wrong but some with square shafts can.
Not what I would call "sharp". The shaft is pretty long, and it's near dead straight in operation.
Not sure how to check/answer that question. This is a triangular shaft that only goes together one way.
"Shudder" may be closer, but I would still say it's stronger than a shudder, although maybe not quite a "rumble". Hard to define using subjective words.
This is a brand new PTO shaft, so not likely to be failing. Also unlikely to be assembled wrong, as I'm pretty sure it can only go together one way - it's triangular and IIRC it has a little bump on one of the corners.
   / Uncomfortable noise on finish mower #7
The fact that the shaft is long and straight in operation is the preferred arrangement.
MAYBE, you just have a harmonic. Something just hits resonance. Usually the frequency varies slightly up and down, not staying at one exact frequency.
I have found that Diesel Engine vibration can find it's way quite a distance into implements.
   / Uncomfortable noise on finish mower #8
I think I know what you are hearing and it is vibration in the PTO shaft caused by the difference in angles of each U joint. If you connect your top link to the pivoting connection on the finish mower, as you should, and then raise the 3ph, you'll see it does not come up level and that puts the Ujoint at the mower end of the shaft at a steeper angle than the one at the tractor end of the shaft. That causes a vibration. If the two angles are the same the vibrations cancel each other out as when you are on level ground.
PTO Shaft Geometry :: John Deere TechTalk – The Source for John Deere Technical Information
Driveshaft Angle and Phasing - YouTube
Very interesting. It seems like the answer provided in the link above is kinda complicated, and would be difficult to implement on a 3-pt setup (as opposed to drawbar, which it seems they are referring to). First I will check and see if the angles are equal. If not, I wonder if/how much I could adjust it with the top link. Also, I believe there may be two attachment points on the mower, essentially changing the length and potentially the angle according to that article.
I will also double-check the phasing but am pretty sure (unless defective from the factory) that it can't be put together wrong.
So... I checked stuff out tonight.
The PTO shaft can only go together one way, and it appears to be in phase.
The link above seems to refer to "pulled" implements as opposed to those "hard mounted" via a 3-pt system. Can't really change anything with a 3-pt.
However, I do see the possibility of the angle changing when the 3-pt link is raised. It seems possible for it to have been designed to eliminate or at least minimize any change, but I don't have the technology to measure/check/verify the change in angles as it lifts. I guess I will have to assume it changes enough to cause this issue, and unless someone can educate me otherwise, accept it as part of "normal" operation. And try to minimize the frequency of such state.
(INOP) 2014 CATERPILLAR 279D SKID STEER (A51242)
(INOP) 2014...
Yale Veracitor 135VX Yale 12,150lb Forklift (A50322)
Yale Veracitor...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
John Deere 693 Corn Head (A50514)
John Deere 693...
