whats the difference between a hipper and a bed shape planter?
  • Thread starter Victor ten Olden
  • Start date
/ whats the difference between a hipper and a bed shape planter? #1
V
Victor ten Olden
Guest
Soon i will be a farm starter. I'm looking on the internet for attachments making tomatobeds.
I can not find the difference between a hipper and a bed shape planter.
Someone help me?
/ whats the difference between a hipper and a bed shape planter? #2
Victor - Welcome to TBN and the forum. I would have to explore the internet for an answer. I'm certain someone with experience will be able to cast light on your question.
/ whats the difference between a hipper and a bed shape planter? #3
Someone help me?
Victor ten Olden,
If you do a internet image search for "hipper farm equipment" you will see mostly simple tillage tools designed to make a raised line of soil which is often intended for planting a single row of seed (maybe sometimes plant seedlings). When you search for "bed shaper" images you will tend to see more implements and farm machines designed to make a wider, more flat-topped planting bed which is most often intended to make a place to place plant seedlings rather than drill or row-crop plant seed. But you will see some crossover between the two image searchers. Different farmers and different farming regions will have varying names for the equipment they use.
As a farm starter one thing you may be interested in is a new machine from Yanmar America that is unique as far as we have been able to tell to date. That is the Yanmar 4-in-1 rotary tiller / bed shaper. You can see a video about it here: How-To Videos - Yanmar Tractor
And you can see a spec sheet here: https://www.yanmartractor.com/resou...ents/YT17-584_RBSD620-Four-In-One-Spec-LR.pdf
At this time (written June 2018), there is a $500 off the purchase price incentive available.
/ whats the difference between a hipper and a bed shape planter? #4
A hipper is a white male, approximately 25 years of age, sporting a flannel shirt, shorts, sandals, a bushy beard and a man bun.
/ whats the difference between a hipper and a bed shape planter? #5
To answer the OP's question...IMO...is: The difference is how wide apart you set the discs...extra wide for "beds"...close together for "hills"...Beds can only be as wide as a the tool bar...!
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
1770 (A58375)
1770 (A58375)
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
