3-Point Hitch help please i have lost all hydraulic pressure on my MT1601D
/ help please i have lost all hydraulic pressure on my MT1601D #1
ch85st
Member
Bulgaria Yambol district
Mitsubishi MT 1601D
Hi
Im having major problems with the hydraulics on a MT1601D
works fine for maybe 20 min after changing all Hydraulic oil, then suddenly nothing with hydraulics work cant lift 3point hitch cant lift Front loader, I have had the Hydraulic pump repaired as i thought it might be that, and i can see i have oil coming in from the pressure pipe in to the (Buck is it called that?) I have now disassembled the whole hydraulic head under the seat and cant figure out if its the control valve thats is the problem or its something else (besides that the control valve is from a MT180D from what i van tell)
perhaps the whole hydraulic system under the seat is from a MT180 D as it dont look like a MT1601D.
does anyone have a clue to what the problem could be? im leaning to that the control valve for some reason just lets oil pass thru with out ever building up any pressure.
Grateful for any help i can get as im not usually working with hydraulics :)
/ help please i have lost all hydraulic pressure on my MT1601D #2
It is called a hydraulic BLOCK.
You need to provide a lot more history about your tractor and its problems.
How long have you had it,
Was the FEL on it when you got the tractor.
Have you been changing hydraulic hoses or valves, adding things like top and tilt or grapple.
Did it ever work properly.
Rarely do you make things better taking hydraulic components apart. Far more likely to make them much worse.
You need a pressure gauge to do the most basic hydraulic diagnostic tests. About $30
Post some photos of the tractor
Dave M7040
Thank you for replying Dave :)
i have had the tractor 2 years and everything has been working fine up till now.
havent changed or added anything with the hydraulics on it.
Only thing that has been done is a new clutch was mounted last month. and actually the problems began after that. i noticed that The hydraulic oil had turned Black the first time it stopped working so i changed all the oil and it worked fine again for about a couple of hours and then no hydraulics again.
Changed the oil once more (yes it was black again) this time i found the filter and pulled it out (the screen is broken on it) can find a new one here so cleaned it and put it back with new oil, again worked fine for a few hours and then nothing. checked the oil black again. This time i cleaned the pump and lines with diesel (poured it in to the filler hole and run the tractor for a minute until i could see it coming back from the return on the front loader) emptied it again filled with new oil and working again :) for an hour or 2 :( . this time i pulled the Hudraulic pump and took it in to a specialize place that only works with repairing Hydraulic pumps, they took it apart and one bearing was stuck so they gave it a full overhaul and it was working fine, mounted it and still no hydraulics. so now took off the Hydraulic block to see if i by any chase could see any faults (as the pump delivers oil to the Block)
only thing i found was that the Block is from a MT180D as the control valve is not looking like the MT1601D. on the control calve the Poppet is (stuck) if its supposed to move i dont know (yet) havent stripped the Control valve yet to see if anything that is supposed to be closed is open :)
I will see if its possible to find one of those Pressure Gauge here in Bulgaria :) 34367994_1975812762429506_7278977068497371136_n.jpg34146456_1975812915762824_3422592836124540928_n.jpg34305153_1975813029096146_2492313949286957056_n.jpg
Well i got the control valve to work, even the stuck poppet and resembled the whole tractor, Still no hydraulic working.
I get oil at pressure line to Hydraulic Block, i have oil coming at return from FEL, tested connections on FEL by opening while tractor running and valve open to the cylinder, sure oil squirts out but not at a very high pressure.
So im back to the Pump i think :( it might pump oil but not at high pressure enough.
/ help please i have lost all hydraulic pressure on my MT1601D #5
Be careful that you don't sustain an injury from high pressure oil which can result in amputation.
I'm thinking possible suction leak. Does the oil appear clear or foamy if run into a container?
thank you for your answer :)
The oil is clear no foam and yes i was careful when i was testing the the connections :) But as not much pressure it wasnt any big squirts :) just oil maybe 5-10 cm up in the air from connection.
/ help please i have lost all hydraulic pressure on my MT1601D #7
If your loader is being supplied by the hydraulic block on the lift housing, your problem is not anything in the lift housing. I'd unhook the loader bucket line & hooking a pressure gauge on the line. See what pressure is at end of stoke.
Thank you for the Answer :)
yes the FEL is supplied by the Hydraulic Block (2 hoses connected with an adapter on the side just under where the High pressure pipe comes in too the Hydraulic block)
I will try what you suggested :)
how ever the Hitch arms also dont work thats why i thought it might be a fault in the Hydraulic block.
I will have to get one of those Pressure gauges :)
Preferably before taking anything more apart (only thing i havent taken off the tractor and checked is the control valve for the FEL, starting to be a bit frustrated now :)
/ help please i have lost all hydraulic pressure on my MT1601D #9
If it is plumbed correctly, which I assume it is, (unless something was changed when doing the clutch) the 3 point & loader are separate systems. The 3 point control valves have a tendency to get dirt in the relief valve & stick, but the loader should still work. The black oil is a puzzle. A common error is not hooking the hydraulics back up after working on the tractor & dead heading the pump. This blows the internal & external pump seals. Usually the hydraulic oil dumps into the motor, not vice versa. What oil are you using?
/ help please i have lost all hydraulic pressure on my MT1601D #10
Do NOT take the FEL valve apart. You will only make things worse.
The valve has no internal seals between the spools and the valve body. The manufacturing tolerances are so fine that without a seal oil cannot escape.
The black hydraulic oil is a clue not to be overlooked.
Is the hydraulic oil the transmission oil? If it is then there is a leaking crankcase seal from your clutch job. Perhaps the seal was put in backwards.
How many hoses on the FEL valve?
Where is the hydraulic pump mounted? When I think about you doing a clutch job, I need to know if your tractor has live pto. If the pump is not mounted on the engine, could you have not assembled the double clutch properly and now there is no power going to the hydraulic pump?
Dave M7040
/ help please i have lost all hydraulic pressure on my MT1601D #11
The transmission is also the hydraulic supply. The pump is engine mounted . Single clutch.
/ help please i have lost all hydraulic pressure on my MT1601D #12
Yeah. A friend was having problems with the hydraulics on a Bolens. He dead headed the pump and it virtually blew right off the block breaking the casting.
Thank you :)
As i didnt do the clutch job myself i cant be sure but i think all hoses are correctly attached.
yes reg the 3 point i did clean the control valve and all moving things is back to moving :)
Regarding the Black oil, when i had the Hydraulic Block off i noticed there was at least 1 cm of Gunk in the bottom of the case :(
So cleaned all that out with diesel. also managed to get hold of a Metal screen for the Filter (found a larger filter for an old Russian Tractor :) ) and managed to attach and seal the metal screen on to my filter.
As i had enough of buying new expensive SAE 80 (transmission/hydraulic Oil) i filtered the oil from last change (only used for 1 hour and Grey not totally black) and put it back for testing if anything worked :(
the oil havent been getting any darker So might have been all the Gunk that made the oil black when the filter screen broke.
MY Last hope :D before sending the whole tractor in to someone that knows how to check and repair a hydraulic system.
I have been thinking that IF there is a relief valve on the control valve for the FEL stuck open, it might be that keeping the whole system from getting pressurized ?
Dave M7040
Thanks again for taking time to read and answer :)
pump is engine mounted, and from what i can tell its pumping oil as its moving thru the system.
As i didnt do the clutch job myself it could be something like you suggests. but as i replied to another answer i found at least 1 cm of Gunk in the hydraulic case and have cleaned that out now + mounted a new screen to the broken filter, so could be that that made the oil black.
Not on this one all seems fine and oil is flowing thru the system.
Im thinking a relief valve on the Control valve for the FEL
Well im Away for a few days so will need to let it sit for a while :)
But im thinking it MIGHT, just Might be a stuck open relief valve on the control valves for the FEL.
Im not sure but when i think about it i dont remember the return from the FEL was having oil going back in to the transmission case all the time before ? might have been just when moving the FEL that the oil was returned to the reservoir ?
Could it be that thats the reason to no hydraulics having pressure?
IF thats not a possible reason to why i have no hydraulics working, i will have to find a specialist on these types of small Jap tractors and have it repaired by them, i have 25 tons of gravel in the yard that needs leveling so must get it working in a near Future :).
/ help please i have lost all hydraulic pressure on my MT1601D #18
Be careful using a pressure gauge. You do NOT want to hook it at the end of a line that might not have the relief valve between the pump and the gauge.
I suggest you first see if your pump can deliver a reasonable volume of oil without worrying about the pressure. Come up with a temporary line connected to the pump output with an open hose which you can direct into a clean bucket so you can reuse the oil. This would be a connection at the put outlet and certainly before the hydraulic block.
The pump should be able to deliver at least 6 US gallons per minute or 22 liters per minutes with the engine at full speed.
If it does not deliver close to that volume you either have a restriction in the suction line, screen or filter. Or a serious air leak into the pump suction.
A pump which will deliver the proper volume will usually deliver the oil at pressure as well so this is a test you can do without a pressure gauge.
There should be oil constantly returning to the reservoir from the FEL valve. A hose in the wrong place does weird things if you removed any or all hoses.
Dave M7040
/ help please i have lost all hydraulic pressure on my MT1601D #19
Wouldn't the relief valves for the loader be downstream of the loader valve, like on the other side of the valve? But maybe your open center valve is hooked up wrong so the oil never stops flowing at low pressure. Not interrupting flow to provide pressure to a given circuit.
/ help please i have lost all hydraulic pressure on my MT1601D #20
I am not trying to argue with you so please keep that in mind.
The typical hydraulic circuit is from the main pump to the power steering which has its own relief valve and is fed by a priority flow control so it always has first opportunity for pressure.
Next is the FEL valve which has its relief on the inlet to the valve block.
Often the FEL will feed the rear of the tractor from a power beyond port on the FEL valve block. If this is what is happening, there will be 7 hoses on the FEL valve not 6. .
The PB circuit will have its own relief valve even though it is limited by the FEL relief valve setting. It can be set lower but will not set higher than the FEL relief.
In addition to the relief valve for the 3 pt and any rear remotes, there is an additional safety valve in the 3 pt circuit to deal with a heavy implement bouncing on the 3 pt arms.
The safety valve is set much higher than any relief valves on the tractor and has to be removed and set up with a special tester also used to calibrate fuel injectors.
With any open center hydraulic circuit, oil is constantly flowing through the individual valves and back to the reservoir all at low pressure. Oil should always be flowing in the open center system.
That is why the output of the pump can never be cut off or dead headed as the pump is a constant displacement type and for each revolution of the pump MUST deliver a specified amount of oil measured in c.c.'s.
Dave M7040
UNUSED FUTURE FTH100-(100)SHEETS OF GALVALUME (A60432)
UNUSED FUTURE...
UNUSED IRANCH 23" GRID SHAPED MINI EXCAVATOR BKT (A60432)
UNUSED IRANCH 23"...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
1995 John Deere 7400 (A60462)
1995 John Deere...
