bandit67
- Joined
- May 27, 2004
- Messages
- 1,610
- Location
- Lake Hartwell, SC
- Tractor
- 2012 B3000 HSDCC 2020 Z251 Zero Turn
When raising the FEL at idle, I can pull the remote joystick back pretty much all the way till it stops and still get the boom to raise. The FEL has a slow and fast boom raise mode based on how far you pull the joystick back.
However, when running the engine at higher RPM, and thus when hydraulic pump output is stronger, the only way I can get the boom to raise is to pull back on the joystick ever so slightly - if I pull back just a bit too far (what my hand is trained to do after 5 years of loader work on this machine), the loader stops raising, like it's going into bypass mode up at maximum boom height. The only way to re-set, and get the raise function to work again, is to quickly push forward to float mode, then go back to raise mode. Simply releasing the joystick back to neutral position does not re-set the lift function. Loader work has become a huge hassle. Every other loader hydraulic function is fine. I have tried switching hydraulic hoses around, and the problem seems to stay at that same port coming out of the loader valve (moving to the new hose/function plugged into the apparent problematic port).
Am I going to need to pull the loader valve apart and possibly replace the internals on the boom side, or is there some sort of simple hydraulic bypass adjustment on the loader valve that needs to be made? It is a remote (wired) joystick from the cab to the loader valve, LA403 loader on Kubota B3000 Cab model. I have confirmed the joystick adjustment (am able to use the joystick lock feature).
Any suggestions? Thanks in advance.
