CH3510 Fel
/ CH3510 Fel #1
Seat time
Kubota, BX2350, Kioti CK3510sehc
I am new here and would appreciate some feedback on the CK3510.
I would like to be able to use the loader with quick attach forks to move containers of fire wood.
They would typically be around 1200 lbs and could be as heavy as 1600 lbs.
I would need to move them from a trailer to a storage area and then to my out door wood boiler.
Has anyone actually measured the lift capacity of the loader on one of these tractors?
Thanks in advance for your feedback.
/ CH3510 Fel #2
1600 lbs out on forks will be a lot. If only lifting to carry height probably work real well. Might not want to go much higher. Length of the bin will matter. The farther out away from the pins you get the less you can lift. You could always load the absolute heaviest on trailer and take that to dealer and do real world test. But a lot of variables involved there to just say it can lift 1800+ at pins so 1600 on forks will be just fine. You will know right away if the machine is fine with your heaviest bin or really struggling.
ps...if you have local dealer maybe check out LS too. They have a lot of lift capacity on many models too but sacrifice lift height a little.
/ CH3510 Fel
Thanks CMV,
Local Kioti dealer does not have any in the lot.
He said he ordered more a month ago but not in yet.
I have a BX Kubota that I purchased new some 10 years ago. It has been a very good machine. When I decided it was time for a bigger tractor I assumed I would be buying Kubota, after some online research and a few trips to my local dealer I was ready to give up the idea because of the size and price of a machine that would do the job.
I even considered a B2350 and backing on the trailer with 3 pt. Forks to move the bins.
I checked with other local dealers, Deere, New Holland, Case. Then a neighbor asked me if I had checked with the Kioti dealer just north of us.
I was not at all familiar with Kioti other than the name.
I went to the dealer and was skeptical at first but now am hopefull.
My local Kubota has been good to me and I am usually a loyal customer but if the product won稚 do the job then it痴 time to move on.
/ CH3510 Fel #4
http://www.tractorbynet.com/forums/...g/396798-kl6010-loader-beast.html#post5104384
I wouldn't go as far as to say "because MY loader does this vs it's specs, YOURS will do that vs it's specs". But this is what mine does for an idea.
You don't have a location listed, but is there another dealer nearby? Does your dealer have a CK4010? That uses same loader so would be fine for your test. CK2610 or DK are different loaders though so won't tell you much - unless the CK2610 can do it (would be a stretch) and save you $$$.
If you like Kubota, I'd try the L's loader on your test bin too. Don't let the spec sheets drive you one way or another alone. My buddies MX for example will lift way over what spec sheet says. Not uncommon for him to get back tires off ground but loader still wants to lift more. Even though my loader beats his by a lot on spec sheets, I think we'd actually be real close in what we could actually do.
Seems like your primary concern for new machine is "will it lift my heaviest bin?". If so, would make sense to just go around to a few different dealers and see what brands can/can't handle your worst case bin. From there you can get into other features, cost, dealer preference, etc.
/ CH3510 Fel
I am a bit north of Lafayette, Indiana.
Local dealer does not have a 4010 either.
We did test the Kubota B2650 which is supposed to lift more than the L 01 series. Even the 3 point on the L's wouldn't lift it. The B2650 3 point did. The L Grand would but it is a lot more money.
The tractor will be used for several things around the home, we have a modest herd of sheep and a few cows.
So moving hay around, and stall clean up come to mind. As well as pushing snow, mowing road sides, etc.
Next closest dealer appears to be Kokomo Indiana,
/ CH3510 Fel #6
I would plan on the loader comfortably being able to lift about whatever it is rated for (to at least a few feet off the ground), on a set of forks. That being said, you need BALLAST to do it safely. Loaded rear tires and a heavy implement hanging off the 3-pt.
What kind of containers are you using for the firewood?
/ CH3510 Fel
I use IBC Totes, cut out one side.
Beet juice in the tires and a box blade on the back. I also have a set of 3 point forks if I need more ballast
/ CH3510 Fel #8
The last ck3510 I had would lift a ton of pellets from a pick up truck. Off the ground it would lift it just enough to be able to move it a cross the yard. Tires were filled and a 1,250lb ballast off the 3pt hitch.
/ CH3510 Fel
That is good to know.
I am leaning more towards a CK3510SEHC.
Not as young as I used to be and the cold winter winds blow pretty much non stop out here.
There are wind farms all around me.
I did notice the SE version gets a different loader with a little more lift capacity.
So with beet juice and some ballast I should be good.
Now I just need to find a local dealer with one on the lot.
Any input pros and cons of the se with a cab?
/ CH3510 Fel
So you have owned multiple ck3510痴.
How long do keep them?
You obviously are a fan since you have had more than 1.
/ CH3510 Fel #11
I think they all get the 4030 loader now (or whatever model # is - they changed to where open & cab all use same one). Good question for dealer, but was a recent change I think.
/ CH3510 Fel #12
I have owned two. I purchased the standard open station model when they first came out. I owned it approximately 2 1/2 years. Had a couple small issues the dealer took care of. It has been a great tractor and has done everything I’ve thrown at it. I decided I wanted to upgrade to a cab model for the same reason you mentioned above.
I got R4 industrial tires with the first one and this time I decided to get the turf tires because I use it a lot on my lawn and figured in my situation they would be best. So far I do like them better. I wasn’t planning on filling them this time but I have now decided too.
As far as the cab goes..... NO REGRETS. It has a very nice fit and finish. Only two small complaints would be that it came with no 12V socket and both front and back work lights are both on one switch. Not a big issue as these are easy fixes.
The first tractor came with a kl4010 loader and this new one came with a kl4030. From my research it seems the kl4010 and kl4030 are very similar with a couple small changes. Lift capacity is the same. The kl4020 lift capacity is I think 100lbs more but max height is a little shorter than the kl4010/30. The bucket on the kl4020 is different than the kl4010/30. Although they have small differences in the specs I’m glad I got the 30 over the 20 but would have liked to get the bucket that’s on the 20.
I’d definitely recommend the cab
Hope this helps.
So you have owned multiple ck3510ç—´.
/ CH3510 Fel #13
HDoilcan....I just got a 4010 with cab, and I have a 12v. It's hiding low on the left side as you sit in the seat. On mine anyways. I'm assuming they all came that way? Hope this helps you..
/ CH3510 Fel
Thank you, Very helpful.
It is nice to hear that you liked the first enough to spend your money on another of the same basics model + cab.
/ CH3510 Fel
I called the next closest dealer who is about an hour away.
They don稚 have a cab CK3510se or CK4010se either and don遞 have any on order.
I understand that inventory is expensive and both dealers said cab versions don遞 sell real well around here.
But how is a customer to know if they want the cab unless the can actually see and experience it.
I don遞 want to order the tractor only to find I feel cramped in a cab with little to no room to move. Or that there are too many blind spots or a number of other possible issues.
I will say that when speaking with both dealers they had s lot of good things to
Say about Kioti and their warranty support.
/ CH3510 Fel #16
Thanks for letting me know.
What’s funny is today I installed the radio and afterwards I took it for a ride through the yard to see how the radio sounds as the tractor is moving etc. as I’m driving I hear something like a washer hitting the floor behind my seat. So I stop and kinda turned while sitting in the seat to check behind the seat and yup I seen the 12v socket. Although an acward spot to have it I’m glad there’s is one.
Never found what sounded like a washer hitting the floor.
/ CH3510 Fel
My local dealer called late yesterday evening.
He located a CK3510se hc about 90 minutes from home.
Hope to make a road trip this coming week.
/ CH3510 Fel
I finally got to see and test drive a CK3510SEHC.We also did a liader lift test 1600 lbs on a skid.
Was able to get it off the ground but was in desperate need of ballast. I am convinced it will handle my totes of wood.
Cab was roomy and did not obstruct my view as much as I feared.
Bottom line I was impressed and ordered one from my local dealer.
My wife and I are leaving on vacation Monday.
Tractor should be in by the time we get back in 2 weeks.
/ CH3510 Fel
I finally got to see and test drive a CK3510SEHC.We also did a loader lift test 1600 lbs on a skid.
/ CH3510 Fel #20
congrats!
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
(10) New CATERPILLAR Keys (A65579)
(10) New...
2018 John Deere 3025E (A64126)
2018 John Deere...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2021 John Deere 4044M (A64126)
2021 John Deere...
