Pushing small stumps into the ground
/ Pushing small stumps into the ground #21
Don't have a video cam, other wise I would film it. You can certainly try it for yourself. Make sure the ground is wet/muddy and use a 6 pound sledge.
Haha thanks but no thanks. I'm only 34 years old, but trying to be nice to my back so it lasts at least 34 more.
I just use the tooth bar on my front loader for sampling removal. I ram the tree over, from a couple angles if needed, until the root ball starts to visually loosen up. Then get a tooth or two under the root ball, curl the loader, and it usually pops right out. It can take a while if the saplings are growing very thick together, but it's sure nice not to have to get off the tractor and hand cut or handle the brush.
Yeah, maybe someday I'll get a real tractor with a FEL and a tooth bar. (And a backhoe and a grapple and a landscape rake and a stump grinder and a drink holder.)
/ Pushing small stumps into the ground #23
this one here will take care of any trees you have.. Cat | D11T/D11T CD Dozer | Caterpillar it's on the order of the one's abandoned on the road to Alaska(free for taking. those need some work)...
/ Pushing small stumps into the ground #24
Your tractor doesn’t have enough weight for that to ever work. You might experiment with building a post pounder. One of the simplest post pounders I’ve seen lifted a weight with roller chain and a sprocket with a few teeth missing. Once it turned to the missing teeth the weight dropped. I could pull those stumps in like an hour with the CTL and the puller. You could probably hirer it out cheaper than dealing with it.
/ Pushing small stumps into the ground #28
That would probably work on a lot of the stumps. I'm too cheap to buy one though.
I guess I'm too cheap to ever get rid of these dang stumps!
A Manual T-post driver would probably do well. Much easier on your back than a sledge -- and you never miss!
/ Pushing small stumps into the ground #29
There's a tool called a "Scizzor lift" or "stone lifter" used by people who do a lot of granite or marble work. Basically a scizzor clamp suspended by a chain. You lower it over the item to be lifted and then pull up with a front loader.
/ Pushing small stumps into the ground #30
Also called a Brush Grubber:
And can be pulled with the drawbar on a tractor:
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59910)
2019 UTILITY VS2DX...
STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
STARCRAFT BUMPER...
