Removing tiny stumps
/ Removing tiny stumps #42
I've though about renting a tractor with a ripper like Gary Fowler suggests, maybe I will.
I'd still like to know if anyone has tried using a chain saw with a de-barker on it.
Frankly, with as many as you have to get rid of. I might try renting a skid steer with what they call a Harley rake on the front. It's sort of like a tiller but with shorter tines, it is usually used to get rid of rocks and smooth out the dirt before planting a lawn, but in my opinion it should work fairly well on your small stumps, especially if they are somewhat loose.
http://www.tractorbynet.com/forums/attachments/183563-harley-rakes-objects.html
Aaron Z
/ Removing tiny stumps #43
I'm not familiar with the OP's trees but I suspect they are shallow rooted "runners". Years ago I hooked a chain to a box elder and pulled...I got 20+/pull.
/ Removing tiny stumps #44
On my property a "tiny" stump is any pine tree stump less than 6" in diameter. When I thin my stands, every spring, I simply leave the stumps. They will be rotted within two years and have turned to dust. Certainly not worth any effort trying to remove them.
Yes they are runners. I have pulled a couple with my 20hp tractor. It was not pleasant. Not enough power.
The area where the stumps are is being transformed into a recreational site.
Gotta get rid of the small stumps as they are ankle busters.
/ Removing tiny stumps #49
I used an old Ford pick-up that had a creeper gear. It grunted.
/ Removing tiny stumps #50
Yes, but not all stumps are like that. It depends on species and climate. I have some small cut off stumps in my yard that were there when I bought the place 16 years ago. Cedar mostly. Just as good as the day I moved in.
/ Removing tiny stumps #51
Yes - I can see how some species need more attention than just lopping them down. There are times I wish my property had mixed species. Not the case - its 100% Ponderosa pine.
