Creek under road. Pipe clogs with branches & leaves, then overflows.
   / Creek under road. Pipe clogs with branches & leaves, then overflows. #11
Personally, I'd be helping back up the pipes and letting them washout. (Lowest cost option to yourself) Once they wash out a couple times give the DEP WQS a call everytime and tell them the road failed. They will be issuing NOV's because of the E&S issues the washed out pipes created. Someone didn't do their homework for the drainage area and SWAG'd a pair of pipes in based on the company footing the bill. Id be willing to bet its a small time operator as well.
calling the government in when your driveway culvert fails, is not a good idea. You could be in for fines as well as cost improve drainage
   / Creek under road. Pipe clogs with branches & leaves, then overflows. #12
The issue is being caused by a change in the roadway that was permitted by the DEP for oil& gas activity. They most certainly would be helpful in the situation because its an E&S issue. If you didn't permit the roadway or install the pipes what grounds do you have to support this claim other than generalizations? I worked with the PA DEP for years with these types of issues. The entity that filed the permit and completed the work is 100% on the hook for the issues they caused. They are not coming after the landowner for a gas well road issue. I'll put money on it.
12'x20' High End Carport (A53316)
12'x20' High End...
Utility Trailer (A52377)
Utility Trailer...
John Deere 2305 Compact Tractor (RIDE AND DRIVE) (A50775)
John Deere 2305...
S/N: 5D121D02416 (A55851)
S/N: 5D121D02416...
2008 Ford Focus Sedan (A55758)
2008 Ford Focus...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
