New McCormick X1.45 won't start
/ New McCormick X1.45 won't start #1
bgoodwill
2018 McCormick X1.45
Brand new 2018 McCormick X1.45 with just 60 hours on it. The dealer forgot to bring the operator's manual when he delivered it and has promised to mail it, but haven't received it yet. At about 55 hours a weird warning light came on the dash. Called dealer, who said it was the exhaust light and I just needed to run it at higher RPMs to clear exhaust. I did (has been running about 1200 RPMS, so ran it up to 2000 RPMS) and it cleared temporarily but came on again and has been on ever since. Yesterday after a few hours running, it started making a terrible clanking noise, almost sounded like a rod knocking, so I immediately shut it off. Then decided maybe it was water in the fuel, so used additive to clear any chance of water and cleaned fuel pump. Now it won't start. Turns over and tries to fire, but immediately stalls. Suggestions before I call the dealer again??
/ New McCormick X1.45 won't start #2
:welcome:
To TBN bgoodwill. We are glad that you joined.
Being that new and under warranty, I would make the dealer fix it.
Yes, ultimately, if necessary, but I was hoping it was something simple that I'm overlooking and I don't have to let the machine sit idle while I wait for them to get a field mechanic out here to work on it.
I thought maybe someone else had experienced a similar issue and knew a quick fix/re-set, but my limited research so far tells me these are not common tractors, so not many people have them?
/ New McCormick X1.45 won't start #4
Sounds like the DPF is clogged completely. Tractor is the same as the Branson 4520R. If you look in the area where the DPF/Muffler goes onto the exhaust manifold there is a small plug that can be removed. If it runs after removal of that plug, the DPF is clogged. Good and Bad thing is its a totally passive system and dependent on the operator to keep it clean. This requires at least 10 minutes per hour of full rpm operation to keep it reliably cleaned. You may be able to get it to clear up by running with the plug removed and max rpms for a few minutes. Do not use it like this due to hot exhaust gases being put directly into the engine compartment. Do keep hood raised while doing this.
Thanks for that suggestion. I will try that first thing in the morning.
Update - pulled that plug and it started right up. Ran it for a while at higher rpms and the light eventually cleared. No time to move dirt today, but hopefully will continue to run well when I need it tomorrow. And you can bet I will remember to blow out exhaust every once in a while.
Thanks again for your help. (Now if I can just get the freakin' dealer to send me that manual so I know what to do for standard upkeep.............)
/ New McCormick X1.45 won't start #7
No problem, glad I could help. Be sure to use plenty of ballast. If it gets to the point it cant move with a bucket of dirt without being in 4wd, its time to add more weight to the rear. In case your dealer didn't mention it, break in service on these tractors is scheduled at 50 hours. All the drain plugs should be marked with yellow paint on the ends. If its anything like the Branson manual you aren't missing much.
Just want to be sure I use the correct oils, etx when servicing.
/ New McCormick X1.45 won't start #9
For the engine, 15W40 CJ-4 Rated oil. Needs to be CJ-4 due to the emissions equipment. CI-4 will make it soot up easier. For the front axle, 80W90 GL-5 Gear Oil, nothing special here at least. For the transmission and hydraulics, a high quality UTF. Needs to meet CaseIH MS1207, Ford 134D, or JD J20C/D specifications. Do NOT use 303 fluid. Will lead to shorten PTO clutch life. As long as the UTF your looking at meets the previously described standards you should be good. Cenex Qwiklift is an excellent oil for the trans if you have Cenex in your area. I will caution that the Engine oil and Transmission Oil Filter do not have good aftermarket crosses and possibly the fuel filter too if it is the new style.
Wow! You are a wealth of information and I thank you profusely. I don't know what I'd be doing without you. The dealer I bought from is turning out to be useless and nobody else seems to be able to even find a reference to this tractor model. They can't be that rare, are they? Anyway, I'm 2 weeks into this and already saying "I shoulda boughta kubota".
/ New McCormick X1.45 won't start #11
I hate to hear that about your dealer. Seems to be the norm nowadays. As long as you can get financed for the floorplan just about anybody can become a dealer, unfortunately. They are not that rare. Just a Branson 4520R with McCormick branding and probably McCormicks own loader instead of the Ansung unit used on the Branson. Overall, it is the best tractor you can get in this size in the US, although I may be a little biased after dealing with Branson for 15 years;). Just enjoy using it. Odds are your experience with other brands of dealers would be comparable. I try to keep an eye on this forum, so post whatever questions you have and I will try to answer them. PM me if you want my email address. That gets checked multiple times a day.
/ New McCormick X1.45 won't start #12
After a lot of research, I decided a wanted a McCormick X145. The dealership is close. I stopped by and they had 4, X135s but no 45s. I salesman was nice but I could tell early on that I knew more about the tractor than he did. I told him I wanted the 45 but all he wanted to do was sell me something they already had. Told me the 45 had the same engine, which I told him it did not. I know they have the same lift capacity but 35 has 3cyl and 45 has 4cyl.
He then told me they have problems bringing in another 45's from different dealerships and alluded that he didn't want to go into the details of it. Then told me they no longer made the 45. I told him that was not correct and then he said it was the cab version they didn't make. I told him I don't want a cab. I asked why don't you just order me a new one. To make matters worse, the second time we went to start a 35 for a test drive, it would not turn over. Took several minutes and seemed to be short in the safety switch.
I had to leave and he was supposed to get me a price on a new tractor and he really wanted to buy my skid steer. Was supposed to call me the next day and I have never heard from him. I guess I'm going to have to go farther out and get a Branson. I do like the McCormick colors better and the iconic name. I have thought seriously about calling the owner, not to complain, but let him know he lost a sale. I guess its for the best because I realized the 45 does not come with hydro unless you get a cab model. I think I would like the hydro.
2014 ISUZU NPR S/A 4X2 17FT BOX TRUCK (A59908)
2014 ISUZU NPR S/A...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
LOT OF 8" & 10" I-BEAMS UP TO 16', MISC TUBING (A62130)
LOT OF 8" & 10"...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
New/Unused Wolverine 45in Bucket Clip on Pallet Forks (A61166)
New/Unused...
