Any one use these quick links
   / Any one use these quick links #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
I am looking for some quiklinks to help in connecting my safety chains to the hitch. Still not sure why no one has figured out how to make a hook that easily connects to a class III hitch. Below is the link to the quicklinks I am considering. My concern is these seem to have a higher WLL than any other I have found.
Amazon.com: Stainless Steel 316 Quick Link 9/16" (14mm) Marine Grade: Industrial & Scientific
This is to connect a new camper to my minivan. The camper is rated at just under 3100lbs. The van has a towing capacity of 3500lbs. The tags on the safety chains said WLL 7700lbs. These chains seem to be extreme overkill. From what I have read is the total chain break strength for the 2 safety chains added together must be equal or greater than the weight of the trailer. I am thinking a 3/8" or 1/2" quicklink might be easier to work with the hooks on my safety chains than the 9/16". That would bring the WLL to 3950lbs or 5500lbs. That is still more than required. I know it would make the quiklink the weakest link but do I need to keep over engineering something just because the person before me did?
   / Any one use these quick links #2
Will a screw pin anchor shackle work? I would try to match the rating of the chain. While it may not be necessary legally it would be nice to have a single chain be able hold in case of an accident.
   / Any one use these quick links #3
I use them on a regular bases and love them but not on safety chains. Seems they may work to attach the hooks just fine.
   / Any one use these quick links #4
This is what I did because the shape of the safety chain holes on a 2017 F250 are not conducive to any kind of a proper sized hook.
I was also considering screw pin shackles. My concern with them is the possibility of them coming unscrewed while bouncing down the highway. I have found a bolt type with a nut and cotter pin which would fix that problem. The quick links could be situated such that gravity would keep the nut closed. I am wanting these to be relatively easy to remove since the hitch is only 7" above the ground. When I am not towing I want to be able to remove them so they don't hit the ground over bumps and such.
   / Any one use these quick links #7
That's what the hole in the pin is for. :D
Bruce
   / Any one use these quick links #9
A good way to use that shape hole is to pass the hook through the hole and hook it back into the chain, assuming your hook will hook into a link. This is also the best way to adjust the length of the chain so it's not too tight, not dragging.
   / Any one use these quick links #10
A good way to use that shape hole is to pass the hook through the hole and hook it back into the chain...
Hey, I'm no expert, but you should never hook to the hitch. As BeeferMan says, pass the chain through the hole in the hitch and attach the hook over a link (not THROUGH a link!). Then use the quick link, in a totally non-load bearing way, to hold the hook to the chain. The quick link is not intended to be a chain extension.
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
IH 470 Disk (A50515)
