Economy PTO.
/ Economy PTO. #1
BufordBoone
Tuscaloosa, Al
Kubota L5740 & M7060
The M7060 we just got has Economy PTO. To engage, you move a lever at the rear of the tractor. Doing so gives 540 rpm on the PTO at approx 1800 engine rpm (vs. the normal ~2200 engine rpm).
I understand that this setting is designed for situations whereby the PTO is way over powered for the task at hand. For example, were I to hook a 4' cutter to this tractor, EPTO would be more than sufficient.
I have read another poster that uses his (same tractor) EPTO for wood chipping and stump grinding.
How should an operator determine when to use EPTO and when not to?
We cut the grass around the cabin every week or two weeks. Therefore it is never very long or heavy. I'm assuming this would be a good EPTO task. On the other hand, we cut the fields twice/year. I'd think normal PTO would be most appropriate for thick, tall grass.
I'm interested in what others think and how they use EPTO with their tractors.
Thanks.
/ Economy PTO. #2
Technically EPTO is for fuel saving -- not so much power reduction.
But yes, you can use it to reduce the power without limiting the PTO speed. It can be handy.
Those operators are smart... they are limiting the power of tasks that the tractor could otherwise bust the implement.
/ Economy PTO. #3
I've used it with a 12' batwing in light grass about a foot tall with no issues.
/ Economy PTO. #5
. . . I'm interested in what others think and how they use EPTO with their tractors. . .
On my 85hp JD tractor, I use the 540E PTO setting for everything except the hay baler.
Your tractor will tell you if it's not right. ie: you will bog the engine in E mode.
/ Economy PTO. #6
Agree with the others I use the E mode for most of the pto work I do brush hogging, tedding, sickle bar mower, generator any thing that I don't need full power for
and throttle down and save fuel and noise.
/ Economy PTO. #7
EPTO is intended to reduce fuel consumption and wear and tear on the engine.
I use EPTO most of the time on my M9960 with a HD Woods BB840X 7' rotary cutter. I can operate the engine at around 1,700 RPM which operates the PTO at around 600 RPM, which is about right for most of my mowing chores.
That said, I mow about as fast as my mowers will cut well (600 PTO RPM provides higher blade tip speed allowing higher ground while, at the same time, increasing engine RPM a bit, resulting in a bit more HP) and there are times when I cannot pull the 7' cutter in heavy cover at the ground speed that I want to maintain while in EPTO.
I plan to replace the 7' cutter with a 15' BW within the next year. Once I do that, I expect that it will never again see EPTO.
SDT
/ Economy PTO. #9
I have it on my t4.75. Used it to finish mow. Did fine. Opted for regular PTO bush hogging last week. Area was overgrown. You will like it. On my t4.75 you have to change it with the engine off.
/ Economy PTO.
Thanks for the info, guys. The assistance this place provides is always appreciated.
/ Economy PTO. #11
My LS doesn't have an economy switch but it does have a 3 speed PTO gear box(540/750/1000). I usually run it in 750 speed but reduce the throttle from 1900 RPM which is PTO speed to about 1400 which is about the ratio of reduction between 540/750 (72%), this gives me slightly over the 540 speed but enough RPM for a little added power. It not only reduces wear on the engine but makes for quieter engine also. I really haven't checked to see if it is saving any fuel but logically it should save about 25%.
/ Economy PTO. #12
My M7060HD12 with a 6' bush hog in 24" grass will run about 550 PTO rpm at 3.2 mph and do a good job. I can't tell any harder load on the motor, it has plenty of hp to handle it. Loving this machine so far. IMG_20180521_150125898_HDR.jpegIMG_20180521_145950850.jpegIMG_20180514_134730230_HDR.jpeg
/ Economy PTO.
Cut the grass in front of the cabin and around the pond today. Ran the M7060 in EPTO mode with the Bush Hog 10' offset cutter. It cut very well. Had been two weeks since last cutting. Around the pond I ran it in 2nd gear. On the long stretches I ran it in 6th gear.
Best part is that the cutter doesn't have any sway on this tractor. The JD 2355 always had some sway. I would have to guess how much to cut around objects.
Another benefit is the M7060 has a tighter turn radius than the JD2355.
And then there is the cab...and air conditioning.
Every time I use this tractor I become more pleased with the decision.
/ Economy PTO. #15
SDT
I run my 15’ batwing in ePTO unless it’s very tall and thick. According to the Nebraska tractor tests the hp difference is about 5hp between the two. Only thing I’ve noticed is it doesn’t like starting the mower when it’s been up and the blades haven’t spun recently. Bump the throttle up and it’s fine. Once it’s been running it’s no problem to get it going
Brett
/ Economy PTO. #16
The engine torque curve tells the story.
By design the 540 rpm pto is operating just over the peak of the engine torque curve.
As the load on the pto increases and the engine slows down, it is actually moving back up the torque curve and can respond easily to a heavier load as it has more torque available.
A pto driven generator is an example of when knowing where you are operating on the torque curve is important as you don't want the engine to suddenly stall if a large load happens at the generator.
If you were running a generator using the lower engine speed pto and a sudden large electrical load happened, your engine could suddenly stall as you are operating on the down slope of the torque curve and the slower the engine rpm the less the torque you have available.
It is a great feature, you just need to understand when it is appropriate to use it.
Dave M7040
/ Economy PTO. #17
Another thing to think about is running it hard and hot enough to let the DPF do its thing. So maybe running at the highest rpm is not all bad?
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
LOT OF MISC SAWS (A62131)
LOT OF MISC SAWS...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
