PTO shaft replacement
/ PTO shaft replacement #1
gersus
Missouri
LS XG3025
I finally was able to find a used brush hog, rotary cutter, whatever you want to call it. ;) I had a hard time finding one that wasnt junk. Anyway, got it home and the u joints aren稚 as good shape as I thought they would be.
I知 debating having someone replace them or just buy a new shaft. The cutter is cureently shear pin not slip clutch and I wouldnt mind switching it over if it isnt too expensive. My other reason for considering buying a new shaft is the plastic sleeve is all busted off the original one.
I知 having a little difficulty knowung which shaft I need. I致e been looking on agrisupply痴 website. Whats the difference between the different series of shafts? Like series 4, 6 etc.
With the cutter hooked up, it measures 48 from the base of pto shaft tractor end to the base of the gear box.
So, is this the shaft that would work?
PTO Shaft - PTO Shafts | Agri Supply 89367
/ PTO shaft replacement #3
You might try just using as is just to make sure it is all functional since a new PTO with a slip clutch may cost more than you paid for the cutter.
Worn U joints can last a long time if greased regularly plus the main load on them is first few seconds of spin up if they do not operate at a step angle LOADED.
I know what you mean about having a plastic sleeve so tall grass does not wrap around the PTO. The son helped me cut it off of a PTO the other day.
Does your gear box show containing any signs of water build up? Our last used mower did and we got them flushed and refilled with factory spec gear oil.
Glad you found you a cutter.
/ PTO shaft replacement #4
I've been here 36+ years. Gave up looking for a used agri equipment 30 years ago. In this part of the world - used agri equipment "our size" just doesn't exist.
/ PTO shaft replacement #5
I get the feeling that there's significantly fewer used tractors and attachments out here on the Pacific coast than in the rest of the country.
I have a slip clutch on my current rotary, the old one was shear pin. I'm not convinced the slip clutch is superior and it requires annual maintenance. On the old one I never broke the pin; I've never noticed the clutch slipping on the new one. When I hit something big, usually a rock that's been rolled up out of the ground, I lift the cutter. I often mow with my hand on the 3pt control for this reason.
One way to figure out what series shaft to use is to look at similar size new cutters and see what they use.
/ PTO shaft replacement #6
When purchasing d-line parts you need the specs from your u-joint (brg cap dia and width) in combination with shaft profile (square, oval, etc). Once the appropriate category is defined all parts interchange. If you currently have a sq profile shaft (na shaft) and want to replace as an assy I would change it to a metric d-line of a similar category. Metric d-lines are generally less expensive and more common, (you can recognize by the shaft profiles like oval, triangle, star). They also can be sized w/out any welding where many NA d-lines would need to be purchased in the proper length as the female side is generally just a welded insert requiring it be cut off to re-size.
I was hoping the solution was to just go down to a farm store and buy one the right length. My current shaft is north american square style with internal clip. Havent measured yet to see specific series.
I dropped my shaft off at a local tractor repair shop to have the u joints replaced.
/ PTO shaft replacement #9
For a while I ran my BX42S Wally chipper on my M6040. I immediately noticed, the first time, that the PTO shaft having been cut to fit my Ford 1710 - too short for the M6040. Took it to a specialty shop in the "big city" and they were able to replace the inner and outer shafts with longer sections. Got an all new PTO for $100.
/ PTO shaft replacement #10
I think you are right. It seems to me that anywhere west of Nebraska has a pretty limited "used tractor and implement" market. Not sure why. I sold a tractor and several unused implements a while back. I barely had time to push the "post" button on Craigslist before the phone started ringing.
They couldnt find a u joint that matched my shaft so I had them order me a new one. I will say, the shop I took it too was real nice and spent probably more time than they shouldve looking for a u joint. Definitely will use them in the future.
/ PTO shaft replacement #12
Fantastic. So refreshing to find a shop with knowledgeable and caring people.
/ PTO shaft replacement #13
Truer words were never spoken, sir.
I am also in the West (albeit in Canada) - and cannot find a decent used implement at a price that would reflect ç*¥sed condition. Sonetimes the dealers have used stuff on their lots...but those are usually just a couple years old and could almost pass for new...and their prices reflect that. 2400 dollars for a used Land Pride cutter is hardly a steal, if you know what I mean. Makes me crazy to see these guys in the MidWest, etc say they picked up this or that å±*ust lying in the weeds on a farmerç—´ lot.
2 Row 3pt Bedder (A64119)
2 Row 3pt Bedder...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 John Deere 6120M (A62180)
2020 John Deere...
