Loader Joystick Problem
/ Loader Joystick Problem #1
ID Corgi Ranch
Relocated to: South Central Oklahoma
1965 Ford 4000, 1025R TLB, 3025E
(Posted in TYM forum before I realized it would get more exposure here)
I have a T454 and I'm a little new to tractors. Using the FEL today I felt a "pop" or "snap" in the joystick. No hydraulic leaks. No other issues.
Now the joystick won't raise the loader. All other functions work fine. The joystick control will lower, dump and curl the bucket...just won't lift it. The joystick is complete limp...no resistance at all, when moving it to the rear (lift position).
I've removed the cover and boot around the joystick but don't see any obvious problems.
Of course the manual is of no use. I can't find an online diagram or parts catalog and can't call the dealer until Monday. Hoping someone might have some insight into what might be the issue.
Here's a few pics of the joystick control box (not sure what it's actually called. It appears to be a sealed unit. The cable that controls the inoperative cylinder appears to be attached at the hydraulic control manifold. I tried to loosen/remove the cable from the cylinder but it's still attached somewhere in the box. So I'm at a loss as to what to do next. Any advice or suggestions?
/ Loader Joystick Problem #2
Is the ball end still on the cable in the joy stick?
In the photo the cable with the arrow is extended, is the valve in the float position?
/ Loader Joystick Problem #3
Just went through something like this...bucket went to the dump position without joystick input. You have a spool valve that is on the hydraulic control valve. One spool controls the up and down the other controls dump and curl. There is a positioner spring in each one that returns the spool valve to neutral when you let go of the joystick. On mine the spring fitting had come loose not allowing the spring to work right. Also the control cable had some play in it. I adjusted and tightened the cable. Took apart the spool valve and cleaned everything up and greased the spring and tightened the fitting. Problem fixed !!! Took about 5 hrs. to fix... Not hard to do, just take your time and make sure everything is clean before re-assembling. I have pics to help you
Here is my post FEL bucket not staying up - TractorByNet
TractorByNet - Compact Tractors & Equipment Resource › Forum › Kioti › Kioti Owning/Operating
I don't know. I unscrewed the cable out of the black box (is that a manifold?) but it won't come out far enough for me to see anything.
No, it's not in the float position. It's not in any position...it's just loose.
I found your thread...but this is a different problem. But now I know what to look for when the seals go bad. Thanks.
/ Loader Joystick Problem #6
You have to go to page 7 and start with post #66 on my thread to where I found the problem to be the spool valve and a loose cable.
/ Loader Joystick Problem #7
When you unscrewed the cable did it come out of the phenolic block completely or did it pull the joy stick handle.
If you trace that cable back to the hydraulic valve is it connected to the valve or has the clevis become disconnected.
/ Loader Joystick Problem #8
I disconnected the cable at the hyd control valve, didn't mess with the joystick end. Mine had a pin that connected the cable to the spool valve at the hyd control valve. This is my Kioti parts diagram but should give you a idea what it looks like.
Parts Finder Michigan Iron & Equipment Morrice, MI (855) 265-459
It pulls the joystick handle.
It's connected. Not loose, not broken.
/ Loader Joystick Problem #11
How did you get the nut off? Is it a standard left to loosen? Do you have to hold the cable from turning somehow?
/ Loader Joystick Problem #12
I had a similar problem and the cable from the joystick to the valve had broken inside the sheath. I had to replace the cable and all was good again.
My TYM dealer told me that you can check by swapping your hydraulic lines to the loader and see if the problem changes to the opposite function. That way if you are stuck out in a field with the bucket down or in a bad position you can get it back to a usable position and make it back to the shop.
My dealer offered me an OEM cable or an after market which appeared to be identical but not in price. The difficult part was getting the joystick back on all three pivot balls. I hade to loosen both cables to allow for play at the joystick to get it on all three pivots.
I hope this helps, good luck.
/ Loader Joystick Problem #13
Just did a joystick replacement on my 3930. If you look carefully the pivot ball not attached to a cable is likely secured by a socket head cap screw from the bottom of the joystick. With that one loose the other pivot balls on the cables go together easily and you are pretty well done.
2020 Nissan Pathfinder SUV (A61569)
2020 Nissan...
2016 GMC Acadia AWD SUV (A61569)
2016 GMC Acadia...
84in. Fork Extensions (A61567)
84in. Fork...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
2017 Dodge Journey SUV (A61569)
2017 Dodge Journey...
2022 CATERPILLAR 299D3 XE SKID STEER (A62129)
2022 CATERPILLAR...
