Backhoe Removed backhoe, grease cylinders while covered?
/ Removed backhoe, grease cylinders while covered? #1
Nemmy
WA
Kubota L47 soon?
I removed the backhoe off my Kubota. The manual says to grease the exposed cylinders while it sits waiting for next use. It doesn't say which grease to use for the cylinders. Should I use the same grease that I put in the pivot zerks or ???
Thanks
/ Removed backhoe, grease cylinders while covered? #2
I don’t think it matters. You’re only trying to prevent the rods from rusting. I’d probably use the wheel bearing grease that’s in a tub.
/ Removed backhoe, grease cylinders while covered? #3
I've been told that white lithium won't hurt the seals (and by inference, other greeses can)
Thanks, was not worried about the rods as much as the seals when I start using it again and some of the grease makes it inside.
/ Removed backhoe, grease cylinders while covered? #5
Dang, now _I'm_ worried. My habit has been to coat exposed rods with LPS3 when the hoe comes off. Clean them off with LPS2 before mounting again.
hmmmm,
Z.
/ Removed backhoe, grease cylinders while covered? #6
Is it very low quality on the chrome? Have cylinders beeing out in the weather for decades and no rust.
/ Removed backhoe, grease cylinders while covered? #7
That might be a stretch. Virtually all the unprotected decades old hydraulic rods I’ve seen are rusted.i wouldn’t bother greasing the rods if it was sitting unused for 2 weeks, but if it’s sitting outside long periods it’s probably a good idea. And whenever possible just leave the cylinders retracted.
/ Removed backhoe, grease cylinders while covered? #8
That would be awesome considering you can get white lithium in a spray from WD40 and other brands. Anyone know if white lithium is definitely ok?
Great thread I’ve wondered the same as I get near to detaching my backhoe for most of the summer while I have my cutter on.
/ Removed backhoe, grease cylinders while covered? #9
I was told this by someone at a big hydraulic repair shop. Still worth confirming.
/ Removed backhoe, grease cylinders while covered? #10
I was told the same by a hydraulic shop. They used it to lube the seals for assembling the cylinders.
Toro 3000 Series Lawn Mower (A61166)
Toro 3000 Series...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Caterpillar 938K Articulated Wheel Loader (A61567)
2015 Caterpillar...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2018 KENWORTH T680...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61568)
Pallet of...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61568)
2012 Ford F-450...
