any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #301
That is a good find. Where did you find it?
   / any toro groundsmaster fans on here? #303
New power unit. Came with deck. Don't need it.
Been asking $4,300.
   / any toro groundsmaster fans on here? #306
I have $3400 invested. Servicable units of similar hours usually go for around $7-8k.
$2900 and it's yours.
I bought a 1963 John Deere 4010 diesel instead
   / any toro groundsmaster fans on here? #307
Is there a good way to check the bidirectional clutch on my 1998 325D Groundsmaster?
The drive shaft had been off before I got it. The ahft had obviously whacked the hydrostat filter and was bent. I cut it and welded on a slightly longer pipe - only about 1/4" longer.
After very few hours, I was snow blowing and the bolt that holds the bidirectional clutch on broke. The clutch slid for ward and off. I beat the hydrostat filter to death again.
While looking at the pieces, I could tell they had replaced the bolt the last time. This time it broke about 3/16" inside the splined shaft.
Is the splined shaft supposed to be fully threaded to the end?
I have yet to check deep the hole is before I hot threads.
I need to make a drill jig so I can try drilling the M8x1.25 bolt out for rethreading. I cane up with 17/64 for a tight tap bit and 6.75, H, 6.8, 6.9 and I for loser fitting tap bits.
I am going to try and drill the bolt out with a left hand bit and hopefully it will come out with the shavings so I can run a tap in and clean the threads.
Does anybody have an idea as to why this has happened to this machine 2x in such a short period of time?
It seems there has to be something that caused this.
Thanks
   / any toro groundsmaster fans on here? #309
Thanks
Nope, never happened with mine on the 328D, it is the same as yours.
It shows to be a long bolt:
   / any toro groundsmaster fans on here? #310
If I remember right, it's about 2 1/2" shoulder bolt. M8 x 1.25 I ordered 4.
I could not find a torque spec though. It does get Removable / Blue Loctite.
1262 (A50490)
1262 (A50490)
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2025 LandHonor BS-12-2500G Bale Spears Skid Steer Attachment (A49462)
2025 LandHonor...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
