any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #301
That is a good find. Where did you find it?
   / any toro groundsmaster fans on here? #303
New power unit. Came with deck. Don't need it.
Been asking $4,300.
   / any toro groundsmaster fans on here? #306
I have $3400 invested. Servicable units of similar hours usually go for around $7-8k.
$2900 and it's yours.
I bought a 1963 John Deere 4010 diesel instead
   / any toro groundsmaster fans on here? #307
Is there a good way to check the bidirectional clutch on my 1998 325D Groundsmaster?
The drive shaft had been off before I got it. The ahft had obviously whacked the hydrostat filter and was bent. I cut it and welded on a slightly longer pipe - only about 1/4" longer.
After very few hours, I was snow blowing and the bolt that holds the bidirectional clutch on broke. The clutch slid for ward and off. I beat the hydrostat filter to death again.
While looking at the pieces, I could tell they had replaced the bolt the last time. This time it broke about 3/16" inside the splined shaft.
Is the splined shaft supposed to be fully threaded to the end?
I have yet to check deep the hole is before I hot threads.
I need to make a drill jig so I can try drilling the M8x1.25 bolt out for rethreading. I cane up with 17/64 for a tight tap bit and 6.75, H, 6.8, 6.9 and I for loser fitting tap bits.
I am going to try and drill the bolt out with a left hand bit and hopefully it will come out with the shavings so I can run a tap in and clean the threads.
Does anybody have an idea as to why this has happened to this machine 2x in such a short period of time?
It seems there has to be something that caused this.
Thanks
   / any toro groundsmaster fans on here? #309
Thanks
Nope, never happened with mine on the 328D, it is the same as yours.
It shows to be a long bolt:
   / any toro groundsmaster fans on here? #310
If I remember right, it's about 2 1/2" shoulder bolt. M8 x 1.25 I ordered 4.
I could not find a torque spec though. It does get Removable / Blue Loctite.
2016 VOLVO VHD TRI-AXLE DUMP TRUCK (A51222)
2016 VOLVO VHD...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
