New XR4155HC on its way!
   / New XR4155HC on its way! #91
Didn’t know it was a ‘96’ but, yes. I have a ‘96’ also.
And here’s the photo of GrandSport #941 I promised a while back Image1525380891.701479.jpg
   / New XR4155HC on its way! #94
Thanks for the info. I went up to Ridgeland last Monday, met Bruce, drove the 4155. Nice tractor. Looks like I may own blue soon!
Good deal, you'll have to let us know if you end up pulling the trigger!
   / New XR4155HC on its way! #95
Nate,
Which tires did you go with , the R1's or the R4's, and are they working out for you?
Steve
   / New XR4155HC on its way! #96
Nate,
Steve
I went with the R4's and fluid filled the rears. Overall I feel that was the best choice for my tractor usage and I would make the same decision today
- I use my tractor for running a finish mower quite often and have done lot of landscape type work around the yard so I didn't want to tear things up like a figured I would do with the R1's.
- I was pleasantly surprised how well they worked moving snow around this winter. Obviously I could get the tires to spin if I tried to push large piles or on the icy spots of my gravel driveway late season (freeze/thaw) but I didn't feel that I absolutely needed chains to get the job done.
- I've done a lot of loader work moving around dirt as well. You can get a pretty good stab into a pile in mid-range (HST trasmission) but if I was trying to get a full scoop into some hard stuff I'd go into low range now and then. Once again, if I tried in low range I could get the tires to spin but that wasn't the norm.
- I've had zero issues pulling around an old 10-12 ft. disc
All that said, if I was going to use my tractor for a majority of more "farm" related work (like pulling ground breaking implements, etc.) I probably would have went with the R1's for best traction.
   / New XR4155HC on its way! #99
Something I find interesting is how different these tractors look in pictures depending on what angle the picture is taken from. On a front corner shot like my profile pic the tractor looks quite large! On a side pic or one from a rear corner the same tractor looks like a much smaller!
   / New XR4155HC on its way! #100
I agree. My wife was really surprised when it showed up too. From our conversations, she thought it was going to be substantially larger than the JD 1520 it is replacing. When they are side by side it becomes really evident that the LS isn't really a "big" tractor!
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2007 Toyota Camry LE (A53314)
2007 Toyota Camry...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2003 Mac 26ft 50 Ton Tri-Axle Dry Van Trailer (A55788)
2003 Mac 26ft 50...
Parker 2600 Gravity Wagon (A50775)
Parker 2600...
