Kubota L345dt Axel oil seal replacement...help!
   / Kubota L345dt Axel oil seal replacement...help! #1
AdamDavid
Kubota L345dt
I need to change the oil seal where the bevel gear case meets the axle case. I have everything taken apart but I can't get the axle case off so I can change the seal. I found this thread but the discussion is about a slightly newer design. According to the parts diagram for the L345dt there is not a c clip until after the seal I want to replace (#8 in the drawing). Axle Case.jpg So my question is is the seal just seized and do I just need to hit the thing harder or is that c clip further up the shaft what is keeping the bevel gear case on? And if so How do I get that c clip of with that bearing and oil seal in the way.
   / Kubota L345dt Axel oil seal replacement...help! #2
:welcome:
To the forum Adam. You came to the right place to get answers.
I do not know anything about that model so I can't help but there a lot of members on here who do and I am sure one of them will be able to.
   / Kubota L345dt Axel oil seal replacement...help! #3
... According to the parts diagram for the L345dt there is not a c clip until after the seal I want to replace (#8 in the drawing). So my question is is the seal just seized and do I just need to hit the thing harder or is that c clip further up the shaft what is keeping the bevel gear case on? And if so How do I get that c clip of with that bearing and oil seal in the way.
I haven't actually done this on any of my L345/L355 machines, but a page from the L355 WSM shows how to do it. The bevel gear case/axle case has to be removed from the tractor.
To separate the bevel case from the axle case, circlip 7 can stay in place, but gear shaft 5 has to be tapped up a little so split collar 3 can be taken out. Then the shaft 5 can be tapped down with 8, 9 & 10. Good luck, Dick B
  • L345DT spindle.pdf
Thanks for the tip and the picture! I was wondering if I needed to take the whole thing off. It is good to have confirmation.:cool2: Wish me luck!
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
1684 (A58375)
1684 (A58375)
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
SKID STEER ATTACHMENT CEMENT MIXER (A58216)
SKID STEER...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2013 Ford F-150 XL (A57148)
2013 Ford F-150 XL...
